trim covers for floor seat brackets?
Postby CaeSly [OP] » October 26th 2018, 3:54am
Hi All. I recently purchased a passenger astro to be used for sleeping when camping/hunting. It has middle bucket seat bolts and rear seat brackets in the floor. Do they make plastic trim pieces or something to cover these up? Been searching but may not being using the right terms, haven't found anything. The bolts stick up and I'd prefer not to cut them off. I realize I could custom fab some piece for that. The rear seat brackets look like they would have some sort of cover piece for when no seat is present. Pic for reference. TIA
CaeSly
Years of Membership: CaeSly has been a member for 1 full year
Alias (AKA): Curtis
Extra Info: LT AWD
  • Middle Seat Brackets
    by TPP » August 6th 2020, 9:26pm in Interior
    August 7th 2020, 10:53pm
  • Remove carpet to install floor?
    by tstol » May 27th 2020, 5:57pm in Interior
    Last post by 90safari View the latest post
    May 31st 2020, 9:59pm
    22
    September 26th 2020, 7:47pm
Re: trim covers for floor seat brackets?
Postby SheldonYoung » October 26th 2018, 12:43pm
Buy an Azek pvc trim board at your Home Center.
Drill a hole for the bolt, as close to the bolt size as possible.
Trim to size.
Bang them on over the bolts for a snug fit.
If you ever need to remove them, split them with a chisel. The pvc will not damage the bolt thread.
'97 Astro (AstroSurf)
'05 Astro
'00 Astro
'01 Safari (Surfari)
SheldonYoung
Years of Membership: SheldonYoung has been a member for 2 full yearsSheldonYoung has been a member for 2 full years
Topics: 10
Alias (AKA): FrankenRodz
Van Model Year: 2001
Postby CaeSly [OP] » October 26th 2018, 2:20pm
That's an idea. And I have some pink foam insulation board I can use to do similar. The rear brackets aren't as big of deal but do they really not make cover pieces for those?
CaeSly
Alias (AKA): Curtis
Extra Info: LT AWD
Postby Leeann_93 » October 26th 2018, 10:34pm
CaeSly wrote:That's an idea. And I have some pink foam insulation board I can use to do similar. The rear brackets aren't as big of deal but do they really not make cover pieces for those?
Nope.
Postby Sailing_Faith » October 27th 2018, 8:44pm
having some insulation under where you are going to sleep is a good idea, and you can get a 4 x 8 sheet of 3/4" in Home Depot.. just drop it in, the bolts will go into it and give you a nice flat surface to snooze on.
Sailing_Faith
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Return to Interior
It is currently September 26th 2020, 7:47pm
Interior Forum
Safariescapepod
in Interior
Date: Sep 19 '20
Time: 10:31pm
SoccerMom4x4
in Interior
Date: Sep 15 '20
Time: 1:45am
vangogo
in Interior
Date: Sep 09 '20
Time: 4:15am
AstroOafAdventurerAstroOafAdventurer is online!
in Interior
Date: Aug 28 '20
Time: 9:25pm
in Interior
Comments: 14
Date: Aug 28 '20
Time: 6:42pm
