Remove carpet to install floor?
Postby tstol [OP] » May 27th 2020, 5:57pm
Hello everyone, I have an interior question. I want to install a floor in my 2003 GMC Safari: plywood with laminate faux wood on top. Everything I've seen shows people removing the carpeting. I'm a busy person, I've never done removed carpeting, and it looks like a big job. My mechanic also renovates cars. He said it would take him several hours to remove the carpeting, meaning a few hundred dollars. So he asked me the question I had already wondered: is there any reason to remove the carpeting? I know I "can" put a wood floor over the top of the old carpeting, but is there any reason I shouldn't? Is there anybody here who has done this that could give positives and negatives of doing it this way?
Thanks in advance.
TStol
tstol
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 12
  • Front carpet replacement
    by tstol » March 10th 2021, 10:21pm in Interior
    Last post by vangogo View the latest post
    March 19th 2021, 10:42pm
  • How to Mold a car carpet? basic tutorial I give it 5 stars
    by GaryMacGuyver » April 21st 2021, 2:26pm in Interior
    April 21st 2021, 4:58pm
    7
    68
    May 6th 2021, 5:19pm
Re: Remove carpet to install floor?
Postby Rod's Trucks » May 28th 2020, 5:59am
My concern would be the carpet will hold moisture if it gets wet (and IMHO, it will eventually). Many of us have had to deal with leaky rear door weatherstripping. So wet carpet is a possible significant concern. And if it wet and gets moldy, you will be pulling up the wood floor to get rid or it.
It really is not that hard to remove the carpet, but the padding might be a bit of trouble if it has stuck down to the floor.
When my carpet got wet, I was able to just roll it up toward the front seats, put a few large blocks of wood under it, lay it back out more or less flat, but off the floor ( on the wood blocks). I set a fan in there for a few days and it dried out just fine.
The carpet will provide some sound deadening, so that might be a consideration if you do remove it, but I think some rigid foam would work pretty well in it's place, or even put in sound deadening mats ( like used in door panels and trimmed to fit ) under the plywood.
Just my $.03 worth.
Rod
Rod's Trucks
Topics: 36
Images: 57
Alias (AKA): Rod and/or WE7X
Postby Leeann_93 » May 29th 2020, 3:53am
Not to mention that the carpet could have been wet in the past and the floor below could already have rust on it that you need to treat before it gets worse.
Much better to get it up, clean and treat then install insulation, underlayment and the flooring.
Postby tstol [OP] » May 29th 2020, 12:56pm
Thank you both for your reply. Makes sense. I'll just take it an hour at a time when I have the time and do it slowly and correctly.
tstol
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 12
Postby Astrofarian » May 29th 2020, 1:56pm
Are you planning on SAVING the carpet, for some reason? If not, then why not just grab a utility knife and blades and remove it the FAST way?
Just a thought....
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby 90safari » May 31st 2020, 9:59pm
Leeann_93 wrote:Not to mention that the carpet could have been wet in the past and the floor below could already have rust on it that you need to treat before it gets worse.
^^This.^^
I ran into that years ago, as I'd find damp carpet while crawling around inside on my knees. I pulled the carpet out, then the factory sound deadener which was still soaked and holding water. I hung the carpet up on a clothes line to dry out, and buzzed the floor before putting some primer and paint on it to seal it off. I've since just tossed the carpet in, but it still needs the seals replaced (they're 30+ years old now).
867378671386681
90safari
Firing on 1 Cylinder (L2)
Topics: 5
Images: 160
Van Model Year: 1990
Extra Info: plus an 88 Astro
Return to Interior
It is currently May 6th 2021, 5:19pm
Interior Forum
Gary MacGuyver
in Interior
Date: Today
Time: 1:49pm
davidgrossmann99
in Interior
Date: Apr 29 '21
Time: 3:35pm
justoneman
in Interior
Comments: 9
Date: Apr 26 '21
Time: 1:56am
justoneman
in Interior
Comments: 9
Date: Apr 26 '21
Time: 1:53am
Olivier02
in Interior
Date: Apr 25 '21
Time: 2:02am
Users browsing this forum: xitxit is online! and 9 guests
