replacement interior screws - image attached
Postby joseluisrivera [OP] » August 3rd 2020, 7:59pm
Anyone have an item # from home depot or amazon for interior replacement screws - black color is fine or silver, matching pewter would be awesome too....image attached of an old one....just trying to save some time when I go to HD.
Thanks in advance.
Jose
joseluisrivera
Years of Membership: joseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full years
Topics: 40
Extra Info: sle
  • Cracked dash removal and replacement?
    by Jakob1994 » September 16th 2020, 8:35pm in Interior
    Last post by SheldonYoung View the latest post
    September 17th 2020, 3:23am
    September 26th 2020, 9:07pm
Re: replacement interior screws - image attached
Postby BrainS0up » August 3rd 2020, 8:41pm
I'm also looking for these.
No luck yet.
Hopefully someone here knows!
BrainS0up
Extra Info: LT 4.3L V6 RWD
Postby dchan51360 » August 4th 2020, 3:05am
If you are near a pick and pull Junk yard, just bring a power screw driver and go pull a hand full. Probably cost you about $5 to get a whole handful
dchan51360
Firing on 7 Cylinders (L1)
Postby Astrofarian » August 4th 2020, 3:09am
dchan51360 wrote:If you are near a pick and pull Junk yard, just bring a power screw driver and go pull a hand full. Probably cost you about $5 to get a whole handful
And, as Red Green says..."OUCH, make sure and get the SHARP kind!"
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby dchan51360 » August 4th 2020, 3:16am
By the way I think the GM part number is 15544780 if it helps you. How many did you need?
dchan51360
Postby joseluisrivera [OP] » August 4th 2020, 6:47pm
Maybe 20, I found a home depot one that may work - will report....removed interior pieces and some screws grew legs, may try to paint the tops too....see how it goes / looks.
Jose
joseluisrivera
Topics: 40
Extra Info: sle
Postby tonydobbs » August 4th 2020, 7:02pm
joseluisrivera wrote:Maybe 20, I found a home depot one that may work - will report....removed interior pieces and some screws grew legs, may try to paint the tops too....see how it goes / looks.
Jose
I have a ton of these from taking out my interior. I'm not sure if I need them or not. Do you need these soon? Also when you were taking them out, did you notice that most of them were stripped?
tonydobbs
Years of Membership: tonydobbs has been a member for 1 full year
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
Postby joseluisrivera [OP] » August 4th 2020, 7:22pm
Woohoo....
They were in good shape / not stripped - all came out easy... just lost some along the way....I will take what you can provide, not in a super rush - it takes me 1 week -5 years to get things done....sometimes sooner or later....
Jose
joseluisrivera
Topics: 40
Extra Info: sle
Postby markmitchmarkmitch is online! » August 4th 2020, 10:01pm
yeah screw that lol kidding couldn't help myself. I think Leeann had a source a while ago.
Firing on 4 Cylinders (L6)
Topics: 597
Images: 20
Extra Info: RS V8
Postby tonydobbs » August 4th 2020, 10:24pm
joseluisrivera wrote:Woohoo....
Jose
I meant that whatever the screws were screwed into was stripped. When I unscrewed the interior pieces, many of those screws were no longer grabbing onto any threads and were just spinning in place.
tonydobbs
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
Postby Leeann_93 » August 5th 2020, 11:41pm
Just remember that most of the interior screws GM used are Posidriv, not Phillips...
Postby DD1 » September 20th 2020, 4:16am
I'm new to the forum and came across this post. I am also searching for these screws. I did not know they were Posidriv, thought they were Phillips. Not sure it makes much of a difference as they were in pretty bad shape. I chopped up the floor molding pretty nicely trying to get them out.
Jose, did you ever find them at home depot? If so, would you share the info about them?
Tony, If you can spare them I could use about 10-20.
Thanks,
Darien
DD1
Alias (AKA): Darien
Extra Info: Cargo Van RWD
Postby Big_kid » September 20th 2020, 3:34pm
Think Mcmaster Carr might have them?
Firing on 6 Cylinders (L7)
Topics: 185
Images: 331
Extra Info: 2WD 5.7 V8
Postby DD1 » September 21st 2020, 3:33am
Big_kid wrote:Think Mcmaster Carr might have them?
I checked. They have Shoulder Screws (learned something new today), but you would need to be able to specify the size. I'm going to try measuring these out today. I found a place that claims to sell them based on the part number provided earlier, but shipping was the same as the screws. The screws were $0.92 each and I want 20 of them which cost $18.40. Initially they wanted over $18 in shipping; I went back and now it's $15.81 (As I think more about it I might have removed something else from my cart. That $34.21 for 20 screws or $1.71 per screw.
Here's the link for the screws.https://www.gmpartsprime.com/genuine/gm-screw_assembly_pan_head_washer_wd_c_r_x_csd-15544780.html?vin=1GCDM19X94B111944&make=Light%20Truck&model=Astro%20%2f%20Safari%20(2WD)&year=2004&submodel=&extra1=&extra2=&filter=()
DD1
Alias (AKA): Darien
Postby DD1 » September 22nd 2020, 8:26pm
They canceled the order because they don't actually have them in stock.
DD1
Alias (AKA): Darien
Return to Interior
It is currently September 26th 2020, 9:07pm
Interior Forum
Safariescapepod
in Interior
Date: Sep 19 '20
Time: 10:31pm
SoccerMom4x4
in Interior
Date: Sep 15 '20
Time: 1:45am
vangogo
in Interior
Date: Sep 09 '20
Time: 4:15am
AstroOafAdventurer
in Interior
Date: Aug 28 '20
Time: 9:25pm
AstroOafAdventurer
in Interior
Comments: 14
Date: Aug 28 '20
Time: 6:42pm
