So, as with many other of these vans, my dash is cracked, and pulling up along the front edge above the gauge cluster.
Seems survey says the number one answer is a carpet cover, but what do you do with where it's pulling up?
It will cover it but look like poo above the gauges, I've tried tucking it back in, but no go.
I lifted it up a bit and looks like it's flat plastic under. I'd seen a post on here somewhere that someone had just removed his.
It seems quit a bit of work to change, but I did see a crackless dash top at the pick and pull.
Anyone have a picture of the dash w/o the top, or the top itself removed from the dash?
Here's what I'm working with, I'm thinking of cutting it back where it's pulled up, or as much of it as I can and carpeting it. Also a different color of carpet and spray painting my doors switch/tweeter panels to match as they've faded and don't match the rest of the door. I will try the heat gun treatment on them as well since that works a treat on restoring black plastic to it's original color.
