Separating seat from riser
Postby tedanderson [OP] » August 13th 2012, 4:32am
Is there a way to separate the manual seats from the riser? I am in the market for a replacement of my driver's seat right now, but being that the passenger seat is in mint condition, I want to swap the left and right seats for now.
Anyhow, I know that the seat can be unbolted from the floor but when I took a closer look I noticed that the lower tracks are riveted into the riser. Is there a way that this can be detached? Preferably I'd like to be able to swap the seats without pulling the risers in the first place but if I have to pull them up to disassemble them, that's fine.
But what I didn't want to do is get the seatbelt latches on the wrong sides if this was the only way to swap seats.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
  • bench seat with seat with shoulder belts
    by simsghost » February 10th 2021, 2:22am in Interior
    February 14th 2021, 4:58pm
  • Front bench seat
    by mglsite » January 14th 2021, 2:56am in Interior
    Last post by mglsite View the latest post
    February 7th 2021, 3:07am
    59
    June 25th 2021, 12:33pm
Re: Separating seat from riser
Postby RECox286 » August 13th 2012, 4:56am
Remove both upholstered seats, leaving the metal part attached to the floor. Run the seat fully forward to get the rear bolts, and
full rearward to get to the front two bolts. Belt attachments stay put. Split the seat bottoms from the seat backs, keep the seat
backs in their respective positions, while rotating the seat bottoms left to right and right to left. Put everything back together and
start wearing out the new driver seat.
I've done this quite a few times over the course of many trucks/years. Keeps the seat back adjustment knob where it should be, and
the seatbelt attachments where they should be. The seat back doesn't usually wear out the way the seat bottom does.
Have fun and keep truck'n
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby tedanderson [OP] » August 13th 2012, 6:16am
Right. That's my question- How do I do that?
Run the seat fully forward to get the rear bolts, and full rearward to get to the front two bolts.
When I do this, all I see are rivets that hold the track to the seat riser. Can you explain in more detail?
tedanderson
Topics: 76
Postby ProStreet_LS1 » August 13th 2012, 10:31pm
4 13mm bolts up inside the sliding track, probably have to feel for them. Slide seat all the way forward to get to front two, slide seat all the way back to get to the back two.
1985 Pro Street Chevy Astro: parted, scrapped & upgraded to
1998 Pro Street Chevy Astro: Tubbed w/ 33x22 rear tires, 350 hp aluminum LS1 V8
PRO STREET 4 LIFE, GEARHEAD 4 LIFE
ProStreet_LS1
Years of Membership: ProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full years
Topics: 54
Extra Info: LS1 V8 Pro Street
Postby Lumpy » August 14th 2012, 12:25am
At some point it's likely simpler to remove both seats and bases entirely, THEN find the bolts/rivets whatever, and remove the seat from the base on the bench instead of in the van.
3/8 air ratchet is a wonderful tool.. :rolling:
Years of Membership: Lumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full years
Postby RECox286 » August 14th 2012, 3:40am
My original post, the answer to your original question post, was quite specific, in that I let you in on the secret handshake
and password: " Set the seat to full forward to access the rear two bolts, and then set the seat to full rearward to access the
front two bolts." Roll the dice, go directly to Jail, do not pass GO, do not collect $200. Leave the metal part of the seat in
place. Don't make this harder than it is... (Ahhh, yis'll catch on fer sure, once you gits the idear.)
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby tedanderson [OP] » August 14th 2012, 11:40am
Hmmmm.. Ok. I found the front bolts by sliding the seat forward. (thanks Tbibadasstro) Now I see that there are bolts between the track and the seat. But the track is permanently attached to the riser. This shouldn't be that difficult to do but I may end up taking the whole thing out just so I can vacuum in the tight spots under the seat.
Thanks for your help guys! :thumbup:
tedanderson
Topics: 76
Postby RECox286 » August 14th 2012, 7:18pm
I apologize Ted, I left my head (it screws on) on the bedside table when I ordered the absolute reverse of what I meant to write.
Seat full foward: front bolts, seat full rearward: rear bolts. ( Track is part of the metal bottom, not part of the upholstered seat.)
I'm quite ready for the obligitory walk to the woodshed, sir !
Uncle boB (See, i told you I neber make mistakes.)
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby tedanderson [OP] » August 15th 2012, 3:10am
Hmm.. this should do. :lol:
tedanderson
Topics: 76
Postby chevymaherchevymaher is online! » August 15th 2012, 3:19am
tedanderson wrote:Hmm.. this should do. :lol:
Now that's funny I don't care who you are.
My old gym teacher saying right now. That's a nice paddle. Where is Maher so I can try it out.
Topics: 91
Postby Seb » January 20th 2013, 2:23am
Just wanted to say thank you Uncle Bob, I changed mine over this afternoon. 160k miles had taken there toll.
Seb
Years of Membership: Seb has been a member for 8 full yearsSeb has been a member for 8 full yearsSeb has been a member for 8 full yearsSeb has been a member for 8 full yearsSeb has been a member for 8 full yearsSeb has been a member for 8 full yearsSeb has been a member for 8 full yearsSeb has been a member for 8 full years
Alias (AKA): Seb
Extra Info: SLX 4.3 V6 RWD 1995
Return to Interior
It is currently June 25th 2021, 12:33pm
Interior Forum
in Interior
Date: Jun 12 '21
Time: 12:45am
Vander
in Interior
Date: Jun 02 '21
Time: 4:46pm
isarfari
in Interior
Date: May 17 '21
Time: 1:58am
SheldonYoung
in Interior
Date: May 16 '21
Time: 2:45pm
SheldonYoung
in Interior
Comments: 14
Date: May 09 '21
Time: 12:09am
