courtesy lights
courtesy lights
Postby wot [OP] » October 18th 2012, 2:37pm
My ’05 Astro well equipped with lots of options does not have right, left, or stepwell courtesy lights. ’05 shop manual shows these courtesy lights, owner’s manual only mentions ‘interior lamps’. I have dome lights and reading lights, but no courtesy lights. N/A on ’05???
wot
Years of Membership: wot has been a member for 10 full yearswot has been a member for 10 full yearswot has been a member for 10 full yearswot has been a member for 10 full yearswot has been a member for 10 full yearswot has been a member for 10 full yearswot has been a member for 10 full yearswot has been a member for 10 full yearswot has been a member for 10 full yearswot has been a member for 10 full years
Images: 2
Alias (AKA): throttle
Extra Info: awd
  • Dash working intermittently all Lights on
    by davidgrossmann99 » April 29th 2021, 3:35pm in Interior
    Last post by davidgrossmann99 View the latest post
    May 11th 2021, 4:43am
  • 2002 Safari Van Map lights
    by Hart547 » May 2nd 2021, 3:33am in Interior
    Last post by Hart547 View the latest post
    May 5th 2021, 5:27pm
    33
    August 5th 2021, 2:37am
Re: courtesy lights
Postby Jasen » October 19th 2012, 3:28am
You don't have what look like little vertical vents facing the step wells down about where the seat belts go into the trim panel?
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Years of Membership: Jasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full years
Topics: 260
Images: 101
Re: courtesy lights
Postby wot [OP] » October 19th 2012, 6:50pm
No. Don't have don't have what look like little vertical vents...
I notice my owner's manual uses the term 'dome courtesy lamps'. Must be they eliminated the stepwell lights in later models. Interesting.
wot
Images: 2
Extra Info: awd
Re: courtesy lights
Postby Jasen » October 20th 2012, 2:39am
Well if you put in a 48 LED dome light, you won't need step well lights. Those things light up the cab and step well extremely well.
200k
Ultra gauge
Topics: 260
Images: 101
Re: courtesy lights
Postby 88astroLT » December 17th 2012, 2:15am
I'm pretty sure GM took those stepwell lamps out in 2003.
88astroLT
88 Astro LT RWD 343k+ 3.23
97 Safari SLE RWD 143k+ 3.42 Limited Slip
88astroLT
Years of Membership: 88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years88astroLT has been a member for 10 full years
Topics: 19
Extra Info: LT 4.3L V6 RWD
Re: courtesy lights
Postby Bengt Weil » April 16th 2018, 12:03am
Anyone know if the wiring harness connections for the step well lights (removed year 2003 and up) are still there? Thinking of transferring the appropriate panels with the courtesy lights from a 1998 to my 2003...
Thanks!
Bengt Weil
Fueling (Full tank)
Fueling (Full tank)
Years of Membership: Bengt Weil has been a member for 8 full yearsBengt Weil has been a member for 8 full yearsBengt Weil has been a member for 8 full yearsBengt Weil has been a member for 8 full yearsBengt Weil has been a member for 8 full yearsBengt Weil has been a member for 8 full yearsBengt Weil has been a member for 8 full yearsBengt Weil has been a member for 8 full years
Topics: 18
Alias (AKA): Glen
Re: courtesy lights
Postby gavio » April 16th 2018, 8:31pm
I've done too many mods to remember all the details, but my best recollection is that I had to run wire to add the step well lights to my '05..... For whatever that's worth.....
gavio
Years of Membership: gavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full years
Topics: 84
Images: 4
Re: courtesy lights
Postby Bengt Weil » April 17th 2018, 5:27am
Thanks - that pretty well confirms what I thought (they thinned out the wiring harness - probably saved $10 with that redesign).
Just noticed today on the 2003 and up, GM spec'd the horn circuit with only one horn instead of two, as on early generations... and yes, the wiring/connector for the second horn is gone as well - WTF? GM did a lot of cost cutting the last 3 years of production!
Bengt Weil
Fueling (Full tank)
Fueling (Full tank)
Topics: 18
Alias (AKA): Glen
Re: courtesy lights
Postby ericstg » April 17th 2018, 7:12am
My 03 still has the connector for second horn.
2003 AWD Astro Cargo, 3+1(plus a shackle) lift, LT245/75R16, it's badass!
Update 12/31/20: It's dead!
https://www.astrosafari.com/viewtopic.p ... 7&t=129113
ericstg
Years of Membership: ericstg has been a member for 3 full yearsericstg has been a member for 3 full yearsericstg has been a member for 3 full years
Images: 4
Extra Info: AWD Cargo
Re: courtesy lights
Postby five10freak » April 17th 2018, 8:23am
I got tired of those little courtesy lights, so I fashioned up some extensions and added white led strips.
five10freak
Years of Membership: five10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full yearsfive10freak has been a member for 8 full years
Topics: 24
Images: 232
Alias (AKA): five10freak
Extra Info: LS 4.3L V6 RWD
Re: courtesy lights
Postby Bengt Weil » April 18th 2018, 5:37am
What looks like the wiring for a second horn on your 2003 is the connector for the temp sensor for the overhead console, I believe. On the pre-2003 vans, there should be three (3) connectors in that section of the wiring loom (2-horn + 1-temp sensor).
Quick test - swap the plug on your horn and see if it works...
Bengt Weil
Fueling (Full tank)
Fueling (Full tank)
Topics: 18
Alias (AKA): Glen
Re: courtesy lights
Postby Vandy_B » May 10th 2018, 11:31pm
Yep...that other connector is for the temp sensor. My '03 didn't have one and I added it. Plug 'n play...even the wiring harness for the overhead console is there tucked underneath the headliner.
Vandy_B
Years of Membership: Vandy_B has been a member for 4 full yearsVandy_B has been a member for 4 full yearsVandy_B has been a member for 4 full yearsVandy_B has been a member for 4 full years
Topics: 33
Images: 19
Alias (AKA): andy
Extra Info: 4.3L V6 AWD
Return to Interior
It is currently August 5th 2021, 2:37am
Interior Forum
Gabor Latte
in Interior
Comments: 33
Date: Jul 30 '21
Time: 4:27am
Gabor Latte
in Interior
Comments: 33
Date: Jul 30 '21
Time: 2:43am
Gabor Latte
in Interior
Comments: 33
Date: Jul 30 '21
Time: 12:52am
Gabor Latte
in Interior
Comments: 33
Date: Jul 30 '21
Time: 12:23am
Gabor Latte
in Interior
Comments: 33
Date: Jul 29 '21
Time: 10:54pm
Users browsing this forum: No registered users and 25 guests
