Lots of interior noises
Postby hamiltonfighter [OP] » August 20th 2013, 4:19am
Just got the van last week and noticed there are a lot of rattles and squeaks from the interior. I know that this is a different ride than we're used to, but I want to see if there were any thoughts as to cutting down on some of the noises.
The first noise the wife wants me to find out about is coming from the sliding door. It rattles and squeaks with every bump.
hamiltonfighter
Years of Membership: hamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full yearshamiltonfighter has been a member for 8 full years
Topics: 33
Images: 5
Re: Lots of interior noises
Postby chevymaher » August 20th 2013, 5:18am
the black pins in thr door that slide into the holes when shut. Grease them it helps them not squeak. Just go through the interior and pull and smack each plastic panel. tighten the offending ones. Removable bench seast track is one usually. Then under the van and wiggle the exhaust heat sheilds and look at shock and body bushings.
Postby AnneSofi » September 25th 2013, 11:27am
Hey was it a resale car? Actually I am also planning to buy one but i am confused weather to go for brand new or take second hand.
AnneSofi
Years of Membership: AnneSofi has been a member for 7 full yearsAnneSofi has been a member for 7 full yearsAnneSofi has been a member for 7 full yearsAnneSofi has been a member for 7 full yearsAnneSofi has been a member for 7 full yearsAnneSofi has been a member for 7 full yearsAnneSofi has been a member for 7 full years
Extra Info: LT 4.3L V6 RWD
Postby chevymaher » September 25th 2013, 1:30pm
AnneSofi wrote:Hey was it a resale car? Actually I am also planning to buy one but i am confused weather to go for brand new or take second hand.
If you find a new one let us know
Postby 97cargocrawler » September 25th 2013, 5:10pm
Replace your bushings with polyurethane. The smoother riding suspension will not only stop tweaking the unibody frame but will also make the stuff attached to it less likely to rattle as well. Worked for me. The only rattle I have now in a bare bones cargo is the sunvisor and that's because I removed the headliner that cushioned the mount.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby SilverBullet1997 » September 25th 2013, 6:02pm
Turn up the radio...
:banana:
No but seriously... The rattle could be coming also from the window latches... I know mine were making a little noise before so I stuffed just a little padding behind the latch to put some pressure on it and keep it from making noise..
Last edited by SilverBullet1997 on September 26th 2013, 5:47am, edited 3 times in total.
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Firing on 6 Cylinders (L2)
Years of Membership: SilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full years
Topics: 54
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Postby crusader1xxx » September 26th 2013, 4:01am
:rofl: :rofl:
Is your van a cargo or passenger? not a lot of information to go on?
chevymaher's advise is the best...bang around and see what makes noise and go from there, sometimes tape can be used to stop things from squeaking...goodluck
crusader1xxx
Years of Membership: crusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full years
Topics: 25
Images: 16
Alias (AKA): Andy
Extra Info: RwD
Postby 97cargocrawler » September 26th 2013, 7:02am
crusader1xxx wrote:...bang around and see what makes noise and go from there, sometimes tape can be used to stop things from squeaking...goodluck
You can bang around all you want and never discover the noises are coming from the unibody itself. Been there, done that. Best to have someone ride in back and find the sources. If they can't, it's probably metal tweaking at the seams, i.e. the unibody. Most likely where the spring hangers bolt to the floor.
97cargocrawler
Topics: 42
Postby kenk » September 26th 2013, 1:23pm
had a rattle in the back doors, rear drivers side, the hook where the latch grabs it was well worn, took it off welded it up ground it down, no more rattle
23217
kenk
Years of Membership: kenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full yearskenk has been a member for 8 full years
Topics: 32
Images: 5
Extra Info: SLT AWD
Postby chevymaher » September 26th 2013, 1:44pm
My vans 2 favorites are the jack cover vibrating. I just take it off and smack it into place real good putting it on. And the real gremlin is the panel over the rear doors. 4-6 inches wide across the top. Smack it and it will stop for weeks till the little X-Mas tree fasteners work loose enough for it to do it again.
On my older model the shifter linkage vibrates on speed bumps.
CC is right the poly body mounts killed a multitude of noise. It wasn't necessarily them but the vibrations were worse when you hit bumps.
My rear end makes racket, I suspected even before CC confirmed the leaf spring bushings. Due to the body mounts making such a huge difference.
Due to the way the rear shocks are mounted they can hit the rear end with worn bushings on the shock. Screwdriver pry test. Yep the what I hearing. paint is worn on the side of the shock.
Exhaust pipe itself will make a noise with out hitting anything. It is mounted with rubber mounts and spring loaded. smack it real good it has a resonance in it. Between bumps and the paint shaker way the V-6 runs at certain RPM's it vibrates alot.
Keep at it. I got mine riding quieter than my durango now. Body mounts made a big difference. It used to be alot louder. I slowly find and customize each factory flaw to make it quiet. It is a ongoing hobby.
Return to Interior
It is currently February 26th 2021, 10:48am
Interior Forum
TheGreatAstroDane
in Interior
Date: Feb 04 '21
Time: 8:22pm
Arrow99
in Interior
Date: Jan 22 '21
Time: 5:25am
Arrow99
in Interior
Date: Jan 21 '21
Time: 4:55am
Attached by: MI_Ghost
MI_Ghost
in Interior
Comments: 13
Date: Jan 19 '21
Time: 6:55pm
copperhead
in Interior
Comments: 17
Date: Jan 18 '21
Time: 3:43pm
