HOW TO: Install an additional rear hatch release switch
Postby intothewild [OP] » November 7th 2013, 1:40am
For a while now, I have toyed with the idea of installing a rear hatch release switch for my dutch doors in the rear of my Astro. I picked up a rear hatch switch from the JY in order to keep it factory looking. The following is what I did to make this work.
Here is the switch being used:
Knowing that the wiring that I need is next to the spare tire, I decided to mount it on the trim piece covering the spare tire, I then spliced into the wiring harness that comes off of the mounted control box:
The wiring is straight forward for the most part. Red goes to Red on the Switch. The green wire goes to the gray wire on the switch. And then black goes to black, however you also have to connect the light blue wire, so in total you are joining three wires, black to black/light blue.
That's it! Viola! I now have the ability to pop the hatch from the drivers switch on the dash, the key fob and now from the inside rear of the van. :rockon:
Here's a short video of it functioning:
http://s1178.photobucket.com/user/chris ... 1.mp4.html
NOTE: I did this on my lunch break with the available items I keep in my van at all times. Now that I have proved the concept to myself, this weekend, I will pull it apart, rewire/color match the wires, solder, heat shrink etc and make it more permanent. I will also take better pictures and do a better write-up, I didn't have much time to type this up right now.
Overall this is a very simple, cheap and very handy mod to do if you do any camping or spend any considerable amount of time in the rear of your van.
intothewild
Years of Membership: intothewild has been a member for 10 full yearsintothewild has been a member for 10 full yearsintothewild has been a member for 10 full yearsintothewild has been a member for 10 full yearsintothewild has been a member for 10 full yearsintothewild has been a member for 10 full yearsintothewild has been a member for 10 full yearsintothewild has been a member for 10 full yearsintothewild has been a member for 10 full yearsintothewild has been a member for 10 full years
Topics: 9
  • Rear hatch latch rod clips?
    by Apache38 » July 14th 2021, 4:36am in Interior
    Last post by jimi_lee View the latest post
    July 14th 2021, 3:31pm
  • How would I install these swivel seats?
    by Vander » June 2nd 2021, 4:46pm in Interior
    Last post by Apache38 View the latest post
    July 14th 2021, 5:22am
    28
    August 5th 2021, 2:30am
Re: HOW TO: Install an additional rear hatch release switch
Postby SilverBullet1997 » November 7th 2013, 4:31am
:goodpost:
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Firing on 6 Cylinders (L2)
Years of Membership: SilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full yearsSilverBullet1997 has been a member for 8 full years
Topics: 55
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Postby Jasen » November 7th 2013, 10:25pm
Nice write up.
I put one in back of my cargo, I don't have power locks or front release, it comes in handy.
I just used a SPST momentary switch and spliced into the orange and black at the hatch module.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Years of Membership: Jasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full years
Topics: 260
Images: 101
Postby WoodButcher » November 7th 2013, 11:08pm
I put mine on the outside. How many times do you walk up to the van with arm loads of stuff and the key is in your pocket?
WoodButcher
Firing on 6 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby intothewild [OP] » November 8th 2013, 12:22am
I've thought about that, but even if it was hidden well I would be too paranoid of it being accessible to thieves.
intothewild
Topics: 9
Postby Herman Wiegman » November 8th 2013, 12:49am
For my camper van, I installed a piece of string which can be pulled on to mechanically release the rear hatch.
Simple.. no power needed.. works every time.
Herminator
Herminator, Niskayuna, NY.......1999 Safari 4.3L SLE (RWD)
Eaton Gov Lok LSD 3.23:1.........Timbren bump stops
Monster 4L60E rebuild ..............Electric fan & FelPro gaskets
10922
Herman Wiegman
Years of Membership: Herman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full yearsHerman Wiegman has been a member for 8 full years
Images: 89
Alias (AKA): Herminator
Extra Info: 4.3L RWD
Postby AstroWill » March 28th 2014, 9:37pm
What vehicle did you get that switch from?
Topics: 109
Images: 484
Postby souri25 » June 1st 2021, 8:01pm
AstroWill wrote:What vehicle did you get that switch from?
im searching for the same switch!!! :confused:
souri25
Return to Interior
It is currently August 5th 2021, 2:30am
Interior Forum
Gabor Latte
in Interior
Comments: 33
Date: Jul 30 '21
Time: 4:27am
Gabor Latte
in Interior
Comments: 33
Date: Jul 30 '21
Time: 2:43am
Gabor Latte
in Interior
Comments: 33
Date: Jul 30 '21
Time: 12:52am
Gabor Latte
in Interior
Comments: 33
Date: Jul 30 '21
Time: 12:23am
Gabor Latte
in Interior
Comments: 33
Date: Jul 29 '21
Time: 10:54pm
Users browsing this forum: No registered users and 22 guests
