Cruise Control quit working
Postby castle_Rock [OP] » August 19th 2009, 2:49pm
I only removed the dash instrument trying to get access to the wiring to the ac/heat control, but for some reason, the cruise control no longer works, i didn't mess with the wiring, steering column or any part. Now I have 2 things that quit working. Starting to get to me.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Years of Membership: castle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full yearscastle_Rock has been a member for 11 full years
Topics: 35
Re: Cruise Control quit working
Postby astro355 » August 19th 2009, 7:28pm
Did you check the fuse?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby castle_Rock [OP] » August 19th 2009, 7:40pm
no i didn't check it yet, but i was just going to add that the windshield wipers, high beam light, and the speed of the wipers work just fine, I'll check the fuse now come to think of it.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby castle_Rock [OP] » August 20th 2009, 7:30pm
I checked the fuse box under the dash, but didn't see a fuse, would it be labeled something else?
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby castle_Rock [OP] » September 4th 2009, 9:06pm
this was posted on the 20th of August, beginning to think my posts are getting ignored...
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby $uperJoe » September 4th 2009, 9:38pm
rarely are posts ignored. its usually that if the situation has not come up to an individual then they do not post back. thats why at this response there are 44 views and only 4 responses. 75% of them are you replying to your own question. this is a catch 22 here. there are some that would feel the way you do that there is an ignoring situation. this is hardly the case. in fact i bet its either a lack of experience by others in this area or more likely because of the inexperience they do not just shoot from the hip to sound smarter than experience permits. this is why almost all the posts about any topic aside from humor or conversation (these based mostly on opinion) has merit in all responses. i would personally rather not have to chase down others ideas of potential problems and waste my time as opposed to wait for one correct diagnosis. this is my own opinion and if others feel similar i bet they can chime in as well.
i am sorry to not be able to help at all in this
i do know that older cruise works off vacuum as well as electronics. recheck the lines behind the ac control and make sure there is no vacuum leak. also if the hose came off the brake pedal it would think the brakes are on and cancel the cruise. this in fact is only if the van has the old style.
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
Postby castle_Rock [OP] » September 4th 2009, 10:08pm
Generally when replying to my own question - I am generally providing more details on my discovery of what I find, esp. if there has been a reply to my post. I am grateful for any replies that come my way and do not ignore the replies, I do generally try replying back in any topic I can.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby traxxasmike » September 6th 2009, 4:50am
Check the vacuum lines going to the cruise control unit. It should be located on top of the intake with a link attached to the throttle.
1994 Chevy Astro, CPI Vortec engine, rebuilt transmission with high energy clutches and kevlar bands. Fairbanks Billet 2-4 apply servo. Cold air intake. 3" high flow cat, edelbrock sdt muffler. 3.73 gears. Mattress in the back!
traxxasmike
Years of Membership: traxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full yearstraxxasmike has been a member for 12 full years
Extra Info: 4.3L CPI V6 RWD
Postby castle_Rock [OP] » September 20th 2009, 10:52pm
traxxasmike wrote:Check the vacuum lines going to the cruise control unit. It should be located on top of the intake with a link attached to the throttle.
Hi,
does the cruise control work solely on the vacuum provided by the ac or a different source?
Thanks
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby castle_Rock [OP] » September 22nd 2009, 12:22pm
never mind, its resolved.
Vehicle Specs:
'94 Safari
162K miles
Ext Rear
castle_Rock
Topics: 35
Postby guyonearth » December 2nd 2009, 8:04am
OK, but what was the problem? It's helpful to post the solution you found, someone else may need to know.
guyonearth
Years of Membership: guyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full years
Topics: 5
Alias (AKA): DeanC
Postby Slime » July 10th 2020, 6:09pm
I know this is an old post, but the cruise control in my van doesn't work if I drop the steering wheel from the standard position. Wasn't a big deal, but odd..
Slime
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: Slime has been a member for 3 full yearsSlime has been a member for 3 full yearsSlime has been a member for 3 full years
Topics: 17
Images: 7
Alias (AKA): slime
Extra Info: Custom Cargo
Return to Interior
It is currently April 11th 2021, 11:48am
Interior Forum
ptysiek
in Interior
Time: 9:15pm
marco_esquondolas
in Interior
Date: Apr 07 '21
Time: 1:45pm
Safarout
in Interior
Date: Apr 07 '21
Time: 3:01am
Attached by: GaryMacGuyver
GaryMacGuyver
in Interior
Date: Apr 04 '21
Time: 11:40pm
in Interior
Date: Apr 03 '21
Time: 1:37pm
