Steering wheel
Steering wheel
Postby Astrodamus [OP] » January 11th 2010, 8:27am
I was wondering could I switch my 98 steering wheel with a steering wheel from any Cadillac truck :confused:
This is what I'm shooting for:
98 GMC Chrome Composite Grill with Caddy emblem
Caddy steering wheel
'96 DeVille Taillights
98 ASTRO EXTENDED CARGO VAN 4.3L V6 FI OHV 12V
***Removed Dead Image***
http://www.youtube.com/98Astrodamus
http://www.cardomain.com/ride/3820465/1
Astrodamus
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Astrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full yearsAstrodamus has been a member for 11 full years
Topics: 13
Alias (AKA): Orlando
Extra Info: EXTENDED CARGO
  • 1996 Steering wheel compatibility? I'm down to bare metal!
    by GaryMacGuyver » April 2nd 2021, 6:03pm in Interior
    April 3rd 2021, 1:37pm
    65
    April 13th 2021, 6:02pm
Re: Steering wheel
Postby d3athm3talh3ad » January 12th 2010, 2:32am
would depend on if you want to keep your airbags or not...it might be possible to swap wheels and keep the airbags, i don't know many people who have swapped their steering wheels and kept the airbags...if you aren't concerned about the airbags, i would recommend comparing a junkyard column with yours to see if the steering wheels would interchange...maybe someone else will chime in who may have done a similar swap...
d3athm3talh3ad
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: d3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full yearsd3athm3talh3ad has been a member for 13 full years
Alias (AKA): that goth chick
Extra Info: 4.3L RWD
Re: Steering wheel
Postby tedanderson » January 12th 2010, 2:48am
If I remember to try this, the next time I am in the junkyard, I will pull the steering wheel off of both vehicles and see if they match up. But the other day when I pulled my horn button off (non-airbag van) I discovered text molded into the center of the wheel that says, "M-VAN ONLY" which I assume to mean that the columns on our vans are different from the ones on full sized trucks.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Re: Steering wheel
Postby Jasen » January 12th 2010, 4:14am
If not, another route may be swapping the column
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Re: Steering wheel
Postby astro355 » January 12th 2010, 4:29am
I must be missing something here. Does the steering wheel from the Cadillac also have an airbag? Either way, it should work just fine. GM has always been good about using the same splined-shaft on all of their vehicles.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Re: Steering wheel
Postby jeff's93astro » January 12th 2010, 4:33am
steering wheel should still interchangeable considering my steering wheel said m van only but was interchangeable with my 88 pickup
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Re: Steering wheel
Postby Astrodamus [OP] » January 12th 2010, 4:45am
Thanks guys for your input :rockon:
astro355 wrote:I must be missing something here. Does the steering wheel from the Cadillac also have an airbag? Either way, it should work just fine. GM has always been good about using the same splined-shaft on all of their vehicles.
yes I think they do have airbags
Jasen wrote:If not, another route may be swapping the column
I thought about this way also because my column now doesn't tilt. :snooty:
Astrodamus
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 13
Return to Interior
It is currently April 13th 2021, 6:02pm
Interior Forum
ptysiek
in Interior
Date: Apr 10 '21
Time: 9:15pm
marco_esquondolas
in Interior
Date: Apr 07 '21
Time: 1:45pm
Safarout
in Interior
Date: Apr 07 '21
Time: 3:01am
Attached by: GaryMacGuyver
GaryMacGuyver
in Interior
Date: Apr 04 '21
Time: 11:40pm
in Interior
Date: Apr 03 '21
Time: 1:37pm
Users browsing this forum: No registered users and 15 guests
