Temp sensor for overhead console
Postby OKSE [OP] » February 25th 2010, 9:45pm
Hei,
where are the sensor for outside temp to overhead console sitting?
I have installed a overhead console and get no temp reading, only 0C.
I have a 96 astro and the console was from a 98 Astro.
OKSE
Years of Membership: OKSE has been a member for 11 full yearsOKSE has been a member for 11 full yearsOKSE has been a member for 11 full yearsOKSE has been a member for 11 full yearsOKSE has been a member for 11 full yearsOKSE has been a member for 11 full yearsOKSE has been a member for 11 full yearsOKSE has been a member for 11 full yearsOKSE has been a member for 11 full yearsOKSE has been a member for 11 full yearsOKSE has been a member for 11 full years
Alias (AKA): Ole
Extra Info: LS 4.3L V6 W AWD
  • wiring info needed-overhead console
    by markmitch » December 31st 2020, 5:46pm in Interior
    January 4th 2021, 6:46pm
    7
    79
    March 6th 2021, 9:02am
Re: Temp sensor for overhead console
Postby unrreal » February 25th 2010, 9:49pm
the sensor is actually located outside the van in the center bracket in front of the radiator right where the horn is, is a little blk unit with a single wire going to it (if i remember right) :D
unrreal
Years of Membership: unrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full years
Topics: 22
Images: 12
Extra Info: 4.3L LS AWD
Postby sfeaver » February 25th 2010, 10:32pm
OC means open circuit.. The sensor is in front of the rad on the bar in the middle.
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Postby OKSE [OP] » February 26th 2010, 8:18pm
Thank you.
What color are there on the wire?
OKSE
Alias (AKA): Ole
Postby sfeaver » February 26th 2010, 11:40pm
Black and Dark Green/Black. Located at center of core support in front of radiator. Goes through convenience center C207 plug. Wires D5 and E. Thats basically just a spot to plug in to seperate harnesses and make the connections. Its under the dash by the fuse panel.
Scott
sfeaver
Topics: 29
Images: 21
Postby OKSE [OP] » February 27th 2010, 10:58pm
Thank you for the help.
OKSE
Alias (AKA): Ole
Postby AstroCan » June 5th 2010, 4:35am
Are the vans without the overhead console already pre-wired?
2004 Astro LS AWD
AstroCan
Years of Membership: AstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full years
Topics: 59
Extra Info: LS
Postby sfeaver » June 5th 2010, 6:39pm
Not sure on that but if you look above where the horns are at see if there is another connector dangling. That would be for the outside air sensor.
sfeaver
Topics: 29
Images: 21
Postby astroturf » June 5th 2010, 6:44pm
Here is a pic. Grill removed. Temp sensor in place. I believe it is a late 90s model. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Gone Blue » June 6th 2010, 3:02am
My Base 98' had the forward outside temp sensor wiring and connector already. The connector with the black and green w/black stripe was taped to the horn wiring behind the grill. I still need to pull my head liner and see if the other half of the wiring that goes to the over head console is there as well. G.B.
2" Overland Van's Lift Kit, 235/75/15 Cooper Discovery ATR Tires, KYB Gas Adjust Shocks, 98' Overhead Console added.........
Gone Blue
Years of Membership: Gone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full years
Topics: 20
Extra Info: AWD Base
Postby Jasen » June 6th 2010, 3:50am
I've got the wire in my horn harness on the 97.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Return to Interior
It is currently March 6th 2021, 9:02am
Interior Forum
TheGreatAstroDane
in Interior
Date: Feb 04 '21
Time: 8:22pm
Arrow99
in Interior
Date: Jan 22 '21
Time: 5:25am
Arrow99
in Interior
Date: Jan 21 '21
Time: 4:55am
Attached by: MI_Ghost
MI_Ghost
in Interior
Comments: 13
Date: Jan 19 '21
Time: 6:55pm
copperhead
in Interior
Comments: 17
Date: Jan 18 '21
Time: 3:43pm
Users browsing this forum: Yandex [Bot] and 9 guests
