Sliding door rattle
Sliding door rattle
Postby beech2000 [OP] » April 28th 2015, 3:26am
I can make the slide door rattling go away by applying finger pressure on upper slide finger. Thoughts?
In an emergency, we call 1911
4086540849
beech2000
Years of Membership: beech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full yearsbeech2000 has been a member for 11 full years
Topics: 26
Images: 41
  • door open - key in ignition buzzer/alarm
    by fellowtraveler » March 31st 2020, 2:26am in Interior
    April 5th 2020, 8:52pm
  • Door issues
    by mutable » May 17th 2020, 2:21am in Interior
    Last post by Old Barney View the latest post
    May 17th 2020, 2:50am
    78
    September 24th 2020, 6:16am
Re: Sliding door rattle
Postby chevymaher » April 28th 2015, 1:05pm
Roller is wearing and got play. Isn't holding it tight to the weatherstipping anymore.
If you figure out anything easy let me know.
Postby h.gil » April 28th 2015, 4:42pm
Bend the arm holding the upper bearing. Just a slight bend towards the door should put more tension at the end of the travel.
Mine had far worse problems as it has a cargo divider and the roller arm would it it as the door closed. The arm had broken off at some point and welded back on; the bearing is broke as well.
Im thinking about shaping a piece of white plastic (HDPE) cutting board and fitting it as a glide bearing. That and a newer weather striping form the JY.
h.gil
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: h.gil has been a member for 5 full yearsh.gil has been a member for 5 full yearsh.gil has been a member for 5 full yearsh.gil has been a member for 5 full yearsh.gil has been a member for 5 full years
Topics: 7
Postby 97cargocrawler » April 28th 2015, 4:56pm
Since I added a window in mine I notice the upper rear corner has a vibration. There ain't nothing back there to pull it in tighter. I suppose I need thicker weatherstrip.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby WoodButcher » April 29th 2015, 12:15am
Adjust the door just like the front doors CC. Put a 2x4 in the partly open door down at the strike / latch area, both hands on the top corner and push. Tweak the door, in your position you may need a step ladder.
WoodButcher
Firing on 4 Cylinders (L6)
Years of Membership: WoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full years
Topics: 30
Images: 512
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Return to Interior
It is currently September 24th 2020, 6:16am
Interior Forum
Safariescapepod
in Interior
Date: Sep 19 '20
Time: 10:31pm
SoccerMom4x4
in Interior
Date: Sep 15 '20
Time: 1:45am
vangogo
in Interior
Date: Sep 09 '20
Time: 4:15am
AstroOafAdventurer
in Interior
Date: Aug 28 '20
Time: 9:25pm
AstroOafAdventurer
in Interior
Comments: 14
Date: Aug 28 '20
Time: 6:42pm
