More NP236 info?
More NP236 info?
Postby SoccerMom4x4 [OP] » September 5th 2016, 5:43am
So Ive been reading up on swapping my stock T-case for the ultra selectable NP236 and it sounds like it should be a direct bolt in ordeal, the only tricky part I can foresee will be the wiring :confused: . Can someone chime in with some more definitive info on the 236? I'd also like to hear from anyone who has actually done the swap. Any advice is gladly taken...
SoccerMom4x4
Years of Membership: SoccerMom4x4 has been a member for 4 full yearsSoccerMom4x4 has been a member for 4 full yearsSoccerMom4x4 has been a member for 4 full yearsSoccerMom4x4 has been a member for 4 full years
Topics: 16
Extra Info: 4.3L V6 4x4
  • Exhaust info needed
    by Wiley » June 25th 2020, 9:00pm in Exhaust
    June 27th 2020, 2:36am
  • alternator info everyone should read
    by markmitch » July 28th 2020, 8:04pm in Electrical
    July 29th 2020, 2:56am
    31
    November 25th 2020, 6:05am
Re: More NP236 info?
Postby HotWire » September 6th 2016, 7:17pm
SoccerMom4x4 wrote:So Ive been reading up on swapping my stock T-case for the ultra selectable NP236 and it sounds like it should be a direct bolt in ordeal, the only tricky part I can foresee will be the wiring :confused: . Can someone chime in with some more definitive info on the 236? I'd also like to hear from anyone who has actually done the swap. Any advice is gladly taken...
I can confirm that I have heard/read the same. I just finished swapping in the np233 and it is a direct fit. I am converting it to manual control, however.
HotWire
Years of Membership: HotWire has been a member for 5 full yearsHotWire has been a member for 5 full yearsHotWire has been a member for 5 full yearsHotWire has been a member for 5 full yearsHotWire has been a member for 5 full years
Topics: 18
Images: 2
Extra Info: 4.3L V6 AWD
Postby Captn.Crunch » September 8th 2016, 3:19pm
Keep reading. Check on the other site also. I've done the swap as has racrx7. It's documented all the way back to when it was just a fuzzy thought in my brain
99 GMC Safari SLE AWD
2" body lift
S-10 rear leafs
NP236 tc
Detroit Truetrac Torsen rear diff w/3.73's
MFactory Torsen equipped front diff-iron
Soon:
Skid plates
rock rails
Captn.Crunch
Years of Membership: Captn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full years
Topics: 21
Images: 4
Extra Info: 4x4 TwinTorsen diffs
It is currently November 25th 2020, 6:05am
Date: Nov 15 '20
Time: 11:02pm
Comments: 14
Date: Oct 27 '20
Time: 5:06pm
Date: Oct 10 '20
Time: 5:57pm
Comments: 22
Date: Oct 05 '20
Time: 1:43am
dit
in 4WD,AWD And Transfer Case
Comments: 17
Date: Sep 06 '20
Time: 11:02pm
