NP236 what to do before install
Postby SoccerMom4x4 [OP] » April 10th 2018, 5:40am
Hey all, I just picked up an NP236 TC, just from an exterior viewpoint everything looks to be in good shape, no oil leakage or cracks. Anyways before I slap this in the van is there anything I should do while its on the bench? Anything to look for or check? I'm not looking to do a complete rebuild if I don't have to. Thanks for any info
SoccerMom4x4
Years of Membership: SoccerMom4x4 has been a member for 4 full yearsSoccerMom4x4 has been a member for 4 full yearsSoccerMom4x4 has been a member for 4 full yearsSoccerMom4x4 has been a member for 4 full years
Topics: 16
Extra Info: 4.3L V6 4x4
  • Remove carpet to install floor?
    by tstol » May 27th 2020, 5:57pm in Interior
    Last post by 90safari View the latest post
    May 31st 2020, 9:59pm
  • 94 Astro no start after fuel pump install
    by grimbeardsly » June 7th 2020, 1:16pm in Engines
    Last post by grimbeardsly View the latest post
    June 21st 2020, 2:18am
    28
    November 25th 2020, 6:00am
Re: NP236 what to do before install
Postby albrow100 » April 10th 2018, 6:18am
I'd like to split the case and reseal all the inputs and output shafts while its easy
if its full of metal it will be time to find a new one
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby WinnieVan » April 11th 2018, 1:07am
do you know it worked before you bought it?
If not -- I'd crack it open and make sure you aren't going to regret installing it and having to buy another one!
That being said -- once you install it once... a swap job is pretty easy.
WinnieVan
Firing on 2 Cylinders (L3)
Years of Membership: WinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full years
Topics: 62
Images: 27
Postby SoccerMom4x4 [OP] » April 11th 2018, 1:37am
No idea if it was a runner or not, looks like for some piece of mind I'll split the cases and seal the shafts. Thanks for the advice, I would definitely rather find out its junk now before I install it! I'll keep this updated
SoccerMom4x4
Topics: 16
Postby 1lowcab » April 11th 2018, 1:54am
If you are opening it up go ahead and replace the chain, especially since you don't know the history of it.
I would also pull the oil screen and the magnet and clean both of those out real good. And grab a pump rub protector plate, the np236 t-cases are prone to oil pump rub just like the np136 cases...the pump will rub a hole right through the case!
1lowcab
Firing on 8 Cylinders (L3)
Topics: 58
Images: 165
Postby Rinny » April 11th 2018, 2:57am
Have you already done all the wiring and did you get the TCCM that went with the 236?
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full years
Topics: 56
Images: 6
Extra Info: 5.7L NP236
Postby jmderyke » April 11th 2018, 4:49am
What to do before 236 install.
Step one disregard 236
Step two install 233c
Step three build manual linkage for cheap or buy it.
Step four have a beer, know you made a better decision, saved a lot of time and money with something that is far more reliable. Doesn't have electronics to break down will shift into 4x4 when needed.
The only thing to look out for is a heavily worn 233c
jmderyke
Years of Membership: jmderyke has been a member for 2 full yearsjmderyke has been a member for 2 full years
Topics: 20
Images: 2
Alias (AKA): jd
Extra Info: 4x4 lifted
Postby Rinny » April 12th 2018, 12:05pm
The 236 is an awful lot of work to have the AWD option.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Topics: 56
Images: 6
Postby SoccerMom4x4 [OP] » April 28th 2018, 6:39pm
I opened up the case last weekend and to my happy surprise the thing looks very clean, no shavings in the oil filter or magnet, the chain and gears look to be nearly perfect. Im going to install a pump rub protector plate and get a gasket and seal kit, what should I use to mate the cases back up? RTV? I like having AWD because in the PNW it rains and snows randomly so I don't mind the extra wiring to have that option. Plus I don't see any bad reviews on the NP236's in general so I figure once wired up it should operate like it should.
SoccerMom4x4
Topics: 16
Postby akforceten » April 28th 2018, 7:09pm
by jmderykejmderyke is online! » April 10th 2018, 7:49pm
/\/\/\what he said /\ /\/\/\
I also live in the PNW and drive all over the mountains. I installed a 233c and can shift on the fly for any road conditions I encounter. keep it simple is my 2cents lol
98638 100250
akforceten
Years of Membership: akforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full years
Topics: 32
Images: 128
Alias (AKA): akforceten
Extra Info: SLE 4x4 7 inch lift
Postby SoccerMom4x4 [OP] » April 28th 2018, 9:13pm
Hmmmmm I'll have to admit I'm a huge fan of keeping things simple. Now ya got me rethinking the 236 :confused: looks like I'll be doing some more research, thanks for your opinions
SoccerMom4x4
Topics: 16
Postby akforceten » April 28th 2018, 9:34pm
it's super easy to do I found my floor shifter out of a 99 dodge 1500 made a bracket to fit the t-case and mounted the shifter where a manual shifter would be
I also put in the s-10 differential and used the above item to be able to lock and unlock the front axle.
almost like an old-school 4x4.
98638 100250
akforceten
Topics: 32
Images: 128
Postby SoccerMom4x4 [OP] » April 29th 2018, 3:25am
Woah, not familiar with the 4x4 posi-lock what does it do? Is it like hub locks? I think Im sold on the 233 TC, easier and I like the idea of not relying on a little motor to shift my 4x4. I got a clean NP236 for sale in Portland!
SoccerMom4x4
Topics: 16
Postby WinnieVan » April 29th 2018, 3:32am
6 months ago I would have bought your 236. But I’m all in for the 233 now. Manual shift for the win.
Sent from my iPhone using Tapatalk
WinnieVan
Topics: 62
Images: 27
Postby 1lowcab » April 29th 2018, 3:55am
SoccerMom4x4 wrote:Woah, not familiar with the 4x4 posi-lock what does it do? Is it like hub locks? I think Im sold on the 233 TC, easier and I like the idea of not relying on a little motor to shift my 4x4. I got a clean NP236 for sale in Portland!
Heres a link to the posi lock
http://4x4posi-lok.com/app_chevy-s.html
Neat little set up really.
1lowcab
Topics: 58
Images: 165
Postby jmderyke » April 29th 2018, 5:12am
Is it weird I'm getting joy from you guys taking the smarter decision and putting the 233c in?
jmderyke
Topics: 20
Images: 2
Alias (AKA): jd
Postby SoccerMom4x4 [OP] » April 29th 2018, 6:03am
No not at all!! Thats why I'm here, to build my van how I want but also smart and dependable!
SoccerMom4x4
Topics: 16
Postby WinnieVan » April 29th 2018, 6:15am
jmderyke wrote:Is it weird I'm getting joy from you guys taking the smarter decision and putting the 233c in?
Time spend wiring the 236 is time spent not using my new 233 on the backroads of the Sierras!
Now I just need to get that new 233!
WinnieVan
Topics: 62
Images: 27
Postby Rinny » April 29th 2018, 2:34pm
The only real advantages o having a 236 that I can see is, (I am running one with a V8)
highway travel with snow or heavy rain, I find myself in that position quite often and it is very nice to have
washed out gravel roads, again I am in that position quite often, 4H will do the same but it is a quicker shift to AWD
short distances of deep mud, again 4H will do it to just a quicker shift to AWD (matter of seconds is all)
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Topics: 56
Images: 6
Postby akforceten » April 29th 2018, 7:51pm
by SoccerMom4x4
with the 233c T-case in 2wd the Astros front differential will be free spinning the front driveline.
by swapping out the Astros front diff with and S-10 front diff of the same gear ratio as your van will not free spin the front driveline since the S-10 front diff locks with a vacuum actuator that's why I used the 4x4 posi lock system so I can control locking and unlocking the S-10 front diff
98638 100250
akforceten
Topics: 32
Images: 128
It is currently November 25th 2020, 6:00am
Date: Nov 15 '20
Time: 11:02pm
Comments: 14
Date: Oct 27 '20
Time: 5:06pm
Date: Oct 10 '20
Time: 5:57pm
Comments: 22
Date: Oct 05 '20
Time: 1:43am
dit
in 4WD,AWD And Transfer Case
Comments: 17
Date: Sep 06 '20
Time: 11:02pm
