front axle seals which brand lasts?
Postby albrow100 [OP] » November 11th 2018, 5:26am
My front axle seals are leaking again on my 1997 safari with 1 1/2in torsion lift (and 2 in spacers)
this set lasted 3000 miles I used Timken seals and I'm pretty sure I've installed them properly (ase certified master tech)
my last set leaked after 2000 miles also Timken brand
Is this normal for lifted vans? should I try ac delco? or national
the bearing on the ends of the axle tubes appear fine, but were not replaced when the front end was rebuilt
there doesn't seem to be any abnormal looseness up/down with the axles
c/v axles are napa brand and are fairly new with the seal surface in good shape
I'm getting real quick at these!
albrow100
Topics: 30
Images: 18
Extra Info: awd
Re: front axle seals which brand lasts?
Postby Corsemoto » November 11th 2018, 7:37am
I started out with Timken and used SKF last time around.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby albrow100 [OP] » November 14th 2018, 4:54am
Thanks I may give those a shot
Are they holding up well?
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby Corsemoto » November 14th 2018, 5:25am
Better than the Timken! I was also careful not to let the cv axles hang or droop in the diff while installing.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby TurnNburn » November 14th 2018, 6:20pm
I haven't had any luck keeping my 100% sealed. replaced these seals 3 times now. Even replaced axles. It stays dry for a couple of thousand miles, and its better then its ever been now, but it still seeps eventually.
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby CopperFiremistCopperFiremist is online! » November 14th 2018, 6:35pm
Have you replaced the needle bearing inside the houseing? I don't have a lift but I have had fairly good luck with a new axle and a GM seal 12471586
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 25
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby albrow100 [OP] » November 15th 2018, 4:09am
I haven't tried to replace the needle bearing there is one on both ends correct?
My diff bearing kit didn't come with the right ones. maybe I'll do that too and use the oem seal you listed
TurnNburn Mine don't leak a whole bunch, they just get wet at 1st and start to form a drip every once in a while on longer drives
I have to top off every 1000 miles or so which is a pain on road trips
I wonder if the modified cv angles is causing some of this
the seal seems like a poor design compared to others I've seen and has no dust boot
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby konybravo » November 15th 2018, 10:33am
Right now I'm in the process of doing this. I managed to source out the parts separately, but meanwhile I found this, and believe, it's what we need: https://www.ebay.com/itm/GM-7-25-IFS-FR ... :rk:1:pf:0
Aloha Kony
konybravo
Years of Membership: konybravo has been a member for 3 full yearskonybravo has been a member for 3 full yearskonybravo has been a member for 3 full years
Topics: 16
Images: 56
Alias (AKA): Kony
Van Model Year: 1996
Extra Info: 4.3 AWD G80
Postby albrow100 [OP] » November 15th 2018, 4:29pm
Aren’t the s10 and Astro needle bearings different?
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby TurnNburn » November 15th 2018, 5:01pm
The 2 piece axle tube of the S10 is different, but the housing is the same other then that. So maybe that needle bearing is different, but I doubt it.
TurnNburn
Green Status (L4)
Green Status (L4)
Postby konybravo » November 15th 2018, 8:24pm
Aloha Kony
konybravo
Topics: 16
Images: 56
Alias (AKA): Kony
Postby albrow100 [OP] » November 16th 2018, 4:56am
thanks for clearing that up
albrow100
Topics: 30
Images: 18
Extra Info: awd
It is currently January 27th 2021, 4:38am
Time: 4:26pm
Date: Jan 10 '21
Time: 5:26pm
Date: Jan 10 '21
Time: 4:31pm
Comments: 52
Date: Jan 09 '21
Time: 5:18pm
Date: Jan 05 '21
Time: 11:22pm
