Manual AWD switch???
Postby Onthewater01 [OP] » May 13th 2019, 2:55am
Has anyone ever tried switching the the AWD manually? You know a switch on the dash to manually activate the AWD transfer case? Or is this just a dumb idea?
I have to believe someone has tried this...
Onthewater01
2005 Astro AWD...work in progress
1995 Astro AWD ...gone but not forgotten
1989 Astro RWD....gone and long forgotten!
Onthewater01
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: Onthewater01 has been a member for 1 full year
Topics: 7
Images: 29
Alias (AKA): Onthewater01
  • 2nd Gen AWD Manual Lock
    by TotoPatron » June 20th 2020, 8:02pm in 4WD,AWD And Transfer Case
    Last post by TotoPatron View the latest post
  • Manual Mirror to Replace a Power Mirror?
    by GodIsBed » October 7th 2020, 1:10am in Exterior
    Last post by GodIsBed View the latest post
    October 24th 2020, 5:01am
    93
    December 4th 2020, 6:07am
Re: Manual AWD switch???
Postby Mmusicman » May 13th 2019, 3:07am
It's a great idea... it's been discussed on numerous occasions.. it could be easily done.. but as far as I know it can't reliably be done, and no one has done it. I almost wired mine manually.
The encoder motor that physically engages the AWD uses a PWM (pulse width modulated) signal. There are two main wires that feed it (from the controller).. they are easily accessible in the DS kick panel. It's feasible that this connection could be interrupted though a manual relay.. but it is also likely that continuous 12vdc would burn up the encoder motor. It would definitely give you manual AWD.. but for how long? It is also unclear how the clutch packs would react to a steady signal vs pulse-width modulated signal... but my guess this is probably not an issue.
I'm still waiting for the day when someone connects 12v to an old encoder motor to see how long it will last.
Of course if someone wanted to get clever, I see no reason why you could devise a a manual circuit that duplicates the PWM that the controller sends.
If you want manual 4x4... I highly recommend the bolt-on replacement NP233C transfer case! No clutches to go bad.. no controller to go bad.. no sensors to go bad.. no encoder motor to go bad.. just pull a lever and pure manual 4x4 operation... hi and lo range too. The conversion is fairly simple and inexpensive, completely bolt-on... and 100% rock solid. :D
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Postby Onthewater01 [OP] » May 13th 2019, 3:31am
Pulse width...interesting....like maybe hook up a 110v inverter, then a transformer to drop it back down to 24v a.c., then run it through a rectifier to to clip the sine wave to 12v d.c. pulses???
Onthewater01
Onthewater01
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 7
Images: 29
Postby AstroWill » May 13th 2019, 8:25pm
Wut?
Images: 443
Postby Mmusicman » May 13th 2019, 11:41pm
Perhaps....
Here's more.. https://www.youtube.com/watch?v=V2U8mWREjok
and more.. https://duckduckgo.com/?q=pulse+width+m ... tor&ia=web
Maybe YOU will be the first! :D
Topics: 73
Images: 49
Postby Captn.Crunch » May 14th 2019, 12:35am
If you want to lock your tc I think your best bet is to use the encoder motor from the np236. It bolts right up to our np136. The 236 encoder has an electric brake that locks the clutch pack in the engaged position. Figure out how to wire it and I think you’ll be good
99 GMC Safari SLE AWD
2" body lift
S-10 rear leafs
NP236 tc
Detroit Truetrac Torsen rear diff w/3.73's
MFactory Torsen equipped front diff-iron
Soon:
Skid plates
rock rails
Captn.Crunch
Years of Membership: Captn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full years
Topics: 21
Images: 4
Extra Info: 4x4 TwinTorsen diffs
Postby MechBob » May 14th 2019, 12:58am
Captn.Crunch wrote:If you want to lock your tc I think your best bet is to use the encoder motor from the np236. It bolts right up to our np136. The 236 encoder has an electric brake that locks the clutch pack in the engaged position. Figure out how to wire it and I think you’ll be good
I think you are right in application,wrong in theory.I think the 236 case has spring loaded detents on the shift shaft.It may very well have a "electric brake" built into the motor,but I doubt it.I may research it later,just not of high importance to me right now,lol.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Onthewater01 [OP] » May 14th 2019, 1:26am
Not of high importance with me right now either, but I am amazed at all the innovation and knowledge I see on this site, and I'm just surprised nobody has done it yet! :ugeek:
Onthewater01
Onthewater01
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 7
Images: 29
Postby MechBob » May 14th 2019, 1:37am
Onthewater01 wrote:Not of high importance with me right now either, but I am amazed at all the innovation and knowledge I see on this site, and I'm just surprised nobody has done it yet! :ugeek:
Why? The factory system works very well,responds quickly.Modify it,and gonna have PCM code problems. 99% of drivers do not need that type of mod. Any serious off road people will change out the transfer case,anyway. I have a 99 astro to build,if I do anything, I will probably put in an older BW awd t case,would suit my needs up here in the mountains.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Mmusicman » May 14th 2019, 2:50am
Personally, I can see the desire for a manual lockup (considering this question has come up on more than one occasion, and I considered it myself)... but whether it is practical, possible, or even necessary is another issue. I guess the idea of having to spin the tires to get the AWD to engage might bother some. Of course that is the beauty of AWD.. that you never have to manually engage it that split second that it is needed. Yes the ultimate is to have the choice of manual and/or automatic engagement, PLUS with hi and lo gear option. Apparently this is done on other vehicles, but not an easy mod on the Astro.
When I was still running my AWD, I actually had my kick panel apart, the wires identified, I temporarily tested it... had the relays and switch ready for install. But I never followed though.. knowing I might unintentionally burn up my encoder motor when I needed it the most. It was that fateful day when I couldn't pull a load off road with my AWD in the soft sand that I realized not only that I wanted manual 4x4 control.. but I also needed 4-LO range as well. Now with the NP233C... my system is completely reliable, fool-proof, and unstoppable, which suits "my" needs.
But it is NO longer an AWD.
Topics: 73
Images: 49
Postby Mmusicman » May 14th 2019, 2:56am
This is my NP233C manual 4x4 (in lo-range) upgrade.. pulling 5000lbs slightly uphill in soft sand on a construction site... NO MORE messing around! Just pull the manual 4x4 shifter lever and go! :mrgreen:
Topics: 73
Images: 49
Postby MechBob » May 14th 2019, 3:11am
What a way to hijack a thread.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Mmusicman » May 14th 2019, 3:18am
MechBob wrote:What a way to hijack a thread.
Thanks! :mrgreen:
But I think we're on the same page.. if you want "manual" operation.. then a manual transfer case is the better way to go!
I still however, want to see someone do the manual AWD switch!
Topics: 73
Images: 49
Postby Captn.Crunch » May 14th 2019, 1:53pm
The 136 and the 236 are identical with the exception of low range. Ive had them apart side by side. The encoder motors are same size and shape and will cross over. The number of wires differ due to the lock circuit on the 236.( see diagram).
If you want to lock in the AWD feature of your 136, get a 236 encoder motor and a four button transfer case switch. If you’re good with wiring schematics, it shouldn’t take too much to figure out. The 4auto button is our AWD. Both 4hi and 4lo will lock the clutch pack in. 2hi will lock it out. No there won’t be any fuel savings there.
I spent a lot of time looking at all of this. I was the first person to do the 236 swap. racrz7 was the first to get it all wired right. I looked at what we are discussing but dismissed it due it’s limited use in real life. The 236 swap gave me a all of what we are talking about and more so if you’re gonna mod - mod with no limits
2" body lift
S-10 rear leafs
NP236 tc
Soon:
Skid plates
rock rails
Captn.Crunch
Topics: 21
Images: 4
Postby Captn.Crunch » May 14th 2019, 5:15pm
BTW Mechbob if you think I may be wrong then please feel free to research and enlighten us all. A couple of I thinks followed by an i doubt it and an I couldn’t be bothered makes for a pretty useless addition to the conversation
2" body lift
S-10 rear leafs
NP236 tc
Soon:
Skid plates
rock rails
Captn.Crunch
Topics: 21
Images: 4
Postby AstroWill » May 14th 2019, 7:06pm
I can see a use case for it. Mom's lawn, you don't want to wait until it slips a little before going to AWD, but prefer AWD over 4WD.
Makes sense to me. Would be nice if you would flip a switch or a momentary push button.
Images: 443
Postby Mmusicman » May 15th 2019, 1:16am
Hey!!! I might have just thought of a simple ingenious way to manually activate your AWD... simply interrupt one of the driveshaft speed sensors and see if this fools the controller into activating your AWD for you.
I suppose an easy way to test would be to unplug one, and see what happens.
Save the applause! :lol:
Topics: 73
Images: 49
Postby MechBob » May 15th 2019, 2:52am
Thanks! :mrgreen:
LOL I was being ornery!
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby MechBob » May 15th 2019, 2:53am
Nice,good info.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby AstroWill » May 15th 2019, 8:35pm
Interrupting the signal from the front prop shaft sensor could work without interfering with the ABS system.
Images: 443
It is currently December 4th 2020, 6:07am
Date: Nov 15 '20
Time: 11:02pm
Comments: 14
Date: Oct 27 '20
Time: 5:06pm
Date: Oct 10 '20
Time: 5:57pm
Comments: 22
Date: Oct 05 '20
Time: 1:43am
dit
Comments: 17
Date: Sep 06 '20
Time: 11:02pm
