No awd
No awd
Postby Rockridge [OP] » November 11th 2019, 3:28pm
2004 Astro. Stock driveline. Lost awd over the summer. No service light, no codes. Checked fuse, it was fine. Changed fluid, it looked fair condition, just swapped the encoder motor as that seemed to be next and no change. Looking for how to test signal to the Encoder motor. Or do I need to disconnected the battery for a while or what am I missing! Snow starts tonight of course!
Rockridge
Firing on 8 Cylinders (L1)
Years of Membership: Rockridge has been a member for 4 full yearsRockridge has been a member for 4 full yearsRockridge has been a member for 4 full yearsRockridge has been a member for 4 full years
Topics: 49
Alias (AKA): Walker
  • No power
    by equitube » September 13th 2020, 4:55am in Electrical
    September 17th 2020, 5:40am
  • 2000 GMC Safari turns over fires intermittent no start
    by Isuzuguru » September 21st 2020, 5:20am in Engines
    Last post by Isuzuguru View the latest post
    September 29th 2020, 1:16am
    34
    March 7th 2021, 3:57pm
Re: No awd
Postby mdconvert » November 11th 2019, 5:18pm
How do you know you lost AWD?
mdconvert
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: mdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full yearsmdconvert has been a member for 12 full years
Topics: 9
Re: No awd
Postby Rockridge [OP] » November 11th 2019, 5:46pm
Front wheels not spinning. Tested on slick dirt trail. Also almost got stuck in a client's yard, wet grass hardly any pitch. The list goes on
Rockridge
Topics: 49
Alias (AKA): Walker
Re: No awd
Postby Leeann_93 » November 11th 2019, 11:53pm
I'm guessing encoder motor. There are a bunch of posts on here about that failing and, iirc, people say not to get the Dorman replacement because the bearings are plastic, not metal, but I could be confusing a couple problems...
Re: No awd
Postby Rockridge [OP] » November 12th 2019, 1:26am
Sorry about that misinformation LeeAnn. I replaced the encoder motor today. Looking to maybe check for signal to it and maybe check to see if my old one is good or bad. Read over a bunch of threads, was hoping the motor swap would square me away. My first astro (8 years ago) was RWD, even with studded snows and weight in the back it would not get up my driveway in winter. Need my awd back! Thanks
Rockridge
Topics: 49
Alias (AKA): Walker
Re: No awd
Postby AstroWill » November 13th 2019, 9:54am
Rockridge wrote:My first astro (8 years ago) was RWD, even with studded snows and weight in the back it would not get up my driveway in winter. Need my awd back! Thanks
Must be one heck of a driveway.
Anyway, I would start with making sure the module is getting power and good ground to the connector(s). What scan tool are you using?
Images: 472
Re: No awd
Postby Onthewater01 » November 14th 2019, 4:41pm
I believe I'm having the same issue...the snow has come to northeast Ohio, and I'm not seeing my front tires spinning when my rears do. I'll be following to find out what your experience is with your repair.
Onthewater01
2005 Astro AWD...work in progress
1995 Astro AWD ...gone but not forgotten
1989 Astro RWD....gone and long forgotten!
Onthewater01
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: Onthewater01 has been a member for 2 full yearsOnthewater01 has been a member for 2 full years
Images: 29
Alias (AKA): Onthewater01
Re: No awd
Postby Mmusicman » November 14th 2019, 7:41pm
* Bad encoder motor is usually most common reason for loss of AWD
* Bad clutches less common.. (would require rebuild).
* Also be sure to check ATC fuse under hood.
* Check connections.
FYI: The controller compares front propshaft speed to rear propshaft speed.
Any variation engages the AWD. Both sensors are located on TC.
If the encoder is engaging/working and there is still no AWD.. it is possible the internal clutches are worn or bad and not working. Also check fluid for issues.
These units are complicated, and ultimately I don't believe there is no definitive way to check them other than putting them to a real world test. Since we don't have snow in South Florida, one way I used to check mine was to jack my rear wheels off the ground (using a rolling floor jack on concrete) and see if the front would engage and attempt to pull me. I'd only go a few inches, but just enough to feel the pull. Extreme care needs to be used using this method.
When they work.. AWD's are the ultimate solution for driving in mud and snow.
Topics: 73
Images: 49
Re: No awd
Postby Rockridge [OP] » November 25th 2019, 12:04am
Is it possible for my awd to be sort of working? We are getting slush/rain now. There is 1.5" on the roads, I got up the driveway but struggled a bit. Friday almost got stuck in in the customers wet yard. Rears were trenching. Felt like fronts were doing nothing.
Going down the driveway tomorrow should be interesting.
Rockridge
Topics: 49
Alias (AKA): Walker
Re: No awd
Postby Leeann_93 » November 25th 2019, 12:08am
I’ve only ever had it work or had it not work, not sorta.
No AWD light?
When the AWD fuse on my ‘99 was bad, the AWD didn’t work and the light didn’t light. Replaced the fuse and all was well.
I would assume that anything else would light the light.
Re: No awd
Postby Rockridge [OP] » November 25th 2019, 12:35am
I have no dash light, fuse is good, t-case fluid is good and just changed the encoder motor. My tires are maybe 1/2 worn. It must be working because back when I had my first RWD Astro it would never have tackled the driveway and I was running studded snows. I'm hoping to get up to my friends garage and put it up in the air soon.
Rockridge
Topics: 49
Alias (AKA): Walker
Re: No awd
Postby Leeann_93 » November 25th 2019, 12:47am
Tires are evenly worn?
Fluid good, new encoder motor, that’s all good. Actually got up the driveway without studs also is good. What kind of tires do you have installed?
Re: No awd
Postby Rockridge [OP] » November 25th 2019, 2:05am
Kuhmo road venture AT2's. Was very impressed last winter when they were new. Wear isn't great, I ran around with a bad idler arm for a bit...
Rockridge
Topics: 49
Alias (AKA): Walker
Re: No awd
Postby The Drummer » November 25th 2019, 2:06am
What if the van is put on stands so that no wheel touches the ground ,then start it , put in D ,i asume that reer wheel would start spinning therefore the awd ,if working would engage and one of the front wheel would spin as well , is it ?
''USE THE TORQUE LUKE ''
and beware of trees ,them nasty wooden things are evil .
The Drummer
Years of Membership: The Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full years
Topics: 16
Images: 46
Extra Info: SLT 4.3 AWD
Re: No awd
Postby plymouthcranbrook » November 25th 2019, 5:43am
My 2001 lost AWD about 2 years ago. Trans repair place could find no codes or reason to not have it work. All the tests they did came out good. Finally decided it might be in the computer. i decided I didn't need AWD that much and so far have managed to stumble through our exciting NE Illinois winters ok. Maybe years of driving in the 60's, 70's, and 80's with rear wheel drive only made it easier. Good luck on finding the problem.
plymouthcranbrook
Years of Membership: plymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full years
Topics: 16
Extra Info: allwheel drive
Re: No awd
Postby Mmusicman » November 27th 2019, 3:42am
The Drummer wrote:What if the van is put on stands so that no wheel touches the ground ,then start it , put in D ,i asume that reer wheel would start spinning therefore the awd ,if working would engage and one of the front wheel would spin as well , is it ?
You should know that this is NOT a valid test. The clutches have a nominal amount of "pre-load" on them.. and the front wheels WILL turn (wheels in air with no load) whether AWD is engaged or not.
The front must turn at a different speed than the rear for true engagement.. then the front MUST see a load to assure the clutches are not slipping.
Topics: 73
Images: 49
Re: No awd
Postby The Drummer » November 28th 2019, 5:01am
apply a little brake then ,maybe ?
The Drummer
Topics: 16
Images: 46
Re: No awd
Postby Old Barney » November 28th 2019, 2:21pm
I have looked at the set of factory manuals and have yet to find an explanation of the voltage needed to turn the encoder motor? Also the duration (amount of time the voltage is applied). If this is known then a momentary voltage could be supplied with clip leads to a power source to test the motor. But with out that information?? Is the voltage just reversed to reverse the encoder?? Is the voltage momentary or constant?
Next a momentary toggle switch could be installed to energize the 4 wheel drive with bright red flashing light to remind the operator to disengage.
Tomorrow morning I will play with my transfer case I have on my transmission. I have a variable supply and listen to hear the motor turn.
Back in the day before computer control life was simple. a dang lever stuck up through the floor and a yank would get you going. even a cable control stuck under the dash with a big knob to pull out for 4 wheel then push in to take it out.
If I had a machine shop I would make a plate with shaft and seal it to take the place of the electric encoder run a cable thing to do the job.
Up north were I spent the first 35 years of my life the salt used on the roads would eat any part of the cars wiring connections included.
Old Barney
Years of Membership: Old Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full years
Topics: 23
Images: 47
Alias (AKA): Barney
Extra Info: awd
Re: No awd
Postby Mmusicman » November 28th 2019, 4:45pm
There are two large gauge black wires in the DS kick panel (easy access) that apply voltage to the encoder. I was going to rig a manual switch (with a pair of relays) years ago, but it was never determined if steady 12v would burn up the encoder, since it is designed to receive 12v PWM (pulse width modulation). Of course now with my 233 TC swap, it no longer matters to me.
I'm sure you can apply direct power.. but unknown for how long.
Here's one previous discussion:
https://www.astrosafari.com/viewtopic.p ... d#p1515432
Here's a little more:
https://www.astrosafari.com/viewtopic.p ... d#p1340042
Topics: 73
Images: 49
Re: No awd
Postby Leeann_93 » November 28th 2019, 5:19pm
The only problem I've ever had with my AWD was when I first got the '99 and the ATC fuse under the hood was toast. Replaced it and have never had to think about AWD again - the '02 and the '05 have worked perfectly with no intervention other than replacing the fluid with AutoTrak 2.
I wonder if it's a speed sensor thing - the control module isn't getting correct info, so it's not applying the clutches and turning the front?
It is currently March 7th 2021, 3:57pm
Comments: 9
Date: Mar 05 '21
Time: 5:04pm
Comments: 9
Date: Mar 05 '21
Time: 4:12pm
Date: Mar 03 '21
Time: 3:42pm
Date: Feb 19 '21
Time: 10:42pm
Date: Feb 15 '21
Time: 4:16am
