Help with 233C swap in 1990 Astro AWD
Postby JoeliusZ28 [OP] » August 2nd 2020, 7:17pm
Hey all,
We have a 1990 astro that we take on off-roading adventures and as such we decided to do the manual transfercase swap using 98+ driveshafts and a 233c tcase from a 2002 S10 pickup.
It all went together with ONE exception. the seal on the front of the tcase did not fit into the adapter on the 700r4. There didn't appear to be any fluid in the adapter, so we thought the back of the trans might have its own seal - therefore we just removed the input seal on the tcase and successfully bolted everything together and it worked! However after the first test drive the tcase seems to be majorly overfilled with trans fluid. I see all over the place that the 233c is a direct swap, but it doesn't appear to be that way for us. What are people doing about this seal? Do you just run the tcase overfilled with fluid? Or do you have to hog out the adapter so that the seal can be used while the two are meshed?
Thanks!
JoeliusZ28
Alias (AKA): Joel
Van Model Year: 1990
Extra Info: Shorty AWD LT
  • 2005 Chavy Astro AWD Cargo Van V-8 Engine swap
    by Porsche928gts » May 26th 2020, 11:55pm in V8 Swap
    Last post by Porsche928gts View the latest post
    May 27th 2020, 10:15pm
  • Repair or swap my engine?
    by G-MO218 » March 28th 2020, 7:44pm in Engines
    March 29th 2020, 6:18pm
    9
    100
    September 24th 2020, 5:38am
Re: Help with 233C swap in 1990 Astro AWD
Postby MechBob » August 2nd 2020, 11:41pm
You probably should have used the transmission to transfer case adapter off the 98.
MechBob
Blue Status (L2)
Blue Status (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Mmusicman » August 2nd 2020, 11:53pm
The 233 is designed to run as a separate unit, with it's own fluid and seals.
My understanding.. it must be mounted to the proper trans adapter.
Firing on 5 Cylinders (L5)
Topics: 72
Images: 49
Postby JoeliusZ28 [OP] » August 3rd 2020, 2:25pm
Yeah, if we had known what we know now we might have pulled a tcase adapter from a 98+ astro while we were at the yard. The adapter we pulled from the 4L60e on the S10 wasn't even close to working. I now realize there were several variations to the 700r4/4L60e as far as these adapters go, and I didn't know that when we started. I ended up getting into contact with another astro guy on facebook, and he said he trimmed out his original adapter on his astro for this exact same issue years ago and it never gave him an issue. So thats what we ended up doing last night. It's all bolted together with the t-case seal in place now. Appreciate the suggestions. If we have problems with this we'll go hunt down the right adapter in the yard but I think this will work. The inner mating surface of this adapter wasn't interlocking with the case anyway.
JoeliusZ28
Alias (AKA): Joel
Postby Mmusicman » August 4th 2020, 12:49am
The back of my stock transmission adapter looks like this... (click to zoom)
The mating surface of the NP233 (with gasket) looks like this..
Topics: 72
Images: 49
Postby JoeliusZ28 [OP] » August 11th 2020, 5:13am
If thats the stock adapter in a newer 2000 Astro that pretty much confirms it wouldn't have worked in ours, so unless there is another donor vehicle out there modifying the stock one was our only option. Our adapter mounts with 4-bolts in the center, and i don't see that on yours.
In other news, we got the electronic tcase switch wired up and working and the t-case is shifting through all the gears!
JoeliusZ28
Alias (AKA): Joel
It is currently September 24th 2020, 5:38am
dit
in 4WD,AWD And Transfer Case
Comments: 17
Date: Sep 06 '20
Time: 11:02pm
Comments: 9
Date: Aug 16 '20
Time: 9:41pm
Date: Aug 05 '20
Time: 8:39am
Date: Aug 03 '20
Time: 2:22pm
Comments: 20
Date: Jul 18 '20
Time: 10:44pm
Users browsing this forum: Olivier02Olivier02 is online! and 1 guest
