AWD to RWD.. how hard?
Postby Alwaysneedhelp [OP] » August 16th 2020, 4:32pm
My front diff totally locked up so I pulled it along with the front axels. I got maybe 6miles down the road and one of my hubs broke. I was wondering if it’s possible to just put RWD hubs on it? Thanks in advance!
Alwaysneedhelp
Extra Info: 4.3 AWD
  • RWD to AWD Q's
    by Cantttype » August 10th 2020, 6:14am in 4WD,AWD And Transfer Case
    Last post by markmitchmarkmitch is online! View the latest post
    December 10th 2020, 6:15am
  • 99 RWD, 98 AWD, 2000 Blazer 4wd and LT1/6spd SALE in AL
    by TowVan » August 23rd 2020, 2:41am in Vans For Sale
    Last post by TowVan View the latest post
    August 23rd 2020, 3:40am
    96
    January 26th 2021, 6:35pm
Re: AWD to RWD.. how hard?
Postby M_a_t_t » August 16th 2020, 7:41pm
Probably not. You can check to see if the ball joints and tie rods are the same between awd and rwd for your year. If they are then you should be able to make it work. You will have to buy rotors and wheel bearings for the 2wd in addition though. Not sure on the calipers.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby petema » August 16th 2020, 8:25pm
By now you are probable aware of the fact that if you had kept the outer cv joints in the hub, it would have kept together. There is a snap ring between the shaft and the joint that keep the axle together. Finding some way of retaining the pretension of the wheel bearing without the axle would be an acceptable technical challenge I believe. P
petema
Years of Membership: petema has been a member for 5 full yearspetema has been a member for 5 full yearspetema has been a member for 5 full yearspetema has been a member for 5 full yearspetema has been a member for 5 full years
Images: 4
Alias (AKA): xm4617
Van Model Year: 1991
Extra Info: CL awd
Postby augidog » August 16th 2020, 8:43pm
petema wrote:By now you are probable aware of the fact that if you had kept the outer cv joints in the hub, it would have kept together. There is a snap ring between the shaft and the joint that keep the axle together. Finding some way of retaining the pretension of the wheel bearing without the axle would be an acceptable technical challenge I believe. P
salvage and insert the outward half of a broken/worn joint and run the nut down on it.
augidog
Years of Membership: augidog has been a member for 1 full year
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby M_a_t_t » August 16th 2020, 9:12pm
I assumed you meant steering knuckle. The rwd doesn't use hub bearings like the awd.
1995 Mercury Tracer
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby petema » August 16th 2020, 9:22pm
M_a_t_t wrote:I assumed you meant steering knuckle. The rwd doesn't use hub bearings like the awd.
You probably answered his question correctly, he may have a couple of RWD knuckles laying around. But finding a way to use awd hubs without the axle shaft is an easier fix, don't you think?
petema
Images: 4
Alias (AKA): xm4617
Extra Info: CL awd
Postby sixsix » August 16th 2020, 9:34pm
One only need to look back in chat about the same time today.
Poor guy.
Remember the 5 Ps
Well, after all... what would Banacek say ?... Anyone that condones the actions of the American People during the Storming of the Capitol are as complicit as the Assholes themselves.
But no way does this let the Democrats or the MSM off the Hook.
Firing on 5 Cylinders (L5)
Topics: 38
Images: 1320
Postby sadglad » August 16th 2020, 9:44pm
petema wrote:
M_a_t_t wrote:.....But finding a way to use awd hubs without the axle shaft is an easier fix, don't you think?
Yes, that is the easy way to do it.
You take apart the AWD front CV joint until you just have the stub left. Put it back through the AWD hub and put the big nut on the threaded end like normal to keep the bearings together. Without that stub and big nut holding the hub together it will break like Alwaysneedhelp found out.
My front diff disintegrated also. I removed the entire drive train from the transfer case forward. I have been driving like that for 5 years with no problems. I just did not have time or money to deal with it at the time so I just took it all out.
sadglad
Years of Membership: sadglad has been a member for 8 full yearssadglad has been a member for 8 full yearssadglad has been a member for 8 full yearssadglad has been a member for 8 full yearssadglad has been a member for 8 full yearssadglad has been a member for 8 full yearssadglad has been a member for 8 full yearssadglad has been a member for 8 full years
Topics: 22
Images: 15
Van Model Year: 2002
Extra Info: 2002 AWD Cargo
Postby augidog » August 16th 2020, 9:49pm
prezactly! heck, needing only the outward half of a bad joint, there may be a pretty long list of compatible parts you can look for in the JY.
augidog
Topics: 16
Alias (AKA): Augie
Postby TBLBill » August 17th 2020, 11:26am
I think that's the best way to do it. I wouldn't count on the knuckle mounting up correctly, especially without seriously messing up the alignment
Sent from my Pixel 2 XL using Tapatalk
TBLBill
Years of Membership: TBLBill has been a member for 2 full yearsTBLBill has been a member for 2 full years
Topics: 12
Images: 42
Extra Info: LS RWD
It is currently January 26th 2021, 6:35pm
Date: Today
Time: 4:26pm
Date: Jan 10 '21
Time: 5:26pm
Date: Jan 10 '21
Time: 4:31pm
Comments: 52
Date: Jan 09 '21
Time: 5:18pm
Date: Jan 05 '21
Time: 11:22pm
