Where do I even start with these..... busted the abs/speed sensor in the front passenger hub and lost awd, swapped the sensor and still have problems. Was able to get codes read but not sure if some are tied together or not. is it 4x4 swap time. I mainly drive in snow so the awd is preferred. Any input helps van is 2001 awd lifted and driven very hard in the mountains
A loose ground had crossed my mind, I can't seem to find the EBCM ground Waite anywhere on my van, should be left rear of the engine by the ebcm module itself correct? Iv referenced a ton of other posts but still can't quite pin the location down.
Ahh I'll have to dig into that this weekend, I did revelry swap out the AC lines and wonder if I knocked the ground wire lose pushing the line down.
23.1K members
