np136 to np236
np136 to np236
Postby Captn.Crunch [OP] » July 18th 2015, 6:35pm
So I've been slowly but surely changing my van over from awd to 4x4. I love the awd in my 99 and didn't want to give it up switching to a manual two speed case. All research shows 136/236 identical other than lo range. I built my two speed by putting 236 guts in a136 case and adding the nv reluctor ring in the front case. I installed and used the 136 encoder motor to check awd operation. All works well. I have downloaded diagrams of the awd and 4x4 tccm plugs. All awd circuits are represented in the 4x4 plug. Now I need to build in the missing 4x4 circuits,swap tccm's and encoder motors. This is starting to look like it might just work
99 GMC Safari SLE AWD
2" body lift
S-10 rear leafs
NP236 tc
Detroit Truetrac Torsen rear diff w/3.73's
MFactory Torsen equipped front diff-iron
Soon:
Skid plates
rock rails
Captn.Crunch
Years of Membership: Captn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full yearsCaptn.Crunch has been a member for 6 full years
Topics: 21
Images: 4
Extra Info: 4x4 TwinTorsen diffs
Re: np136 to np236
Postby gavio » July 18th 2015, 8:25pm
Holy smoke, Crunch, I'm impressed..... Not something I would ever try to duplicate, but I can't wait to see it done :rockon:
gavio
Topics: 77
Images: 4
Re: np136 to np236
Postby Captn.Crunch [OP] » July 18th 2015, 11:02pm
Thanks gavio
So far it's been a bolt on operation.The trick has been no down time for my DD. the wiring is the first real step into the unknown so it's really been fun so far. I'm just hoping when I'm done, it actually works!
2" body lift
S-10 rear leafs
NP236 tc
Soon:
Skid plates
rock rails
Captn.Crunch
Topics: 21
Images: 4
Re: np136 to np236
Postby gavio » July 19th 2015, 1:27am
Well, shoot, now you're gonna make me think I should try to duplicate it.... After you show us how!
gavio
Topics: 77
Images: 4
Re: np136 to np236
Postby Captn.Crunch [OP] » July 19th 2015, 4:20pm
Oh believe me-if this works you'll hear about it. When I googled np236 in a safari I found some who thought about it but backed away due the electronic mayhem. So it appears I'm the first to get this far. My thinking is that GM is lazy and is not gonna make unit specific items. They will underutilize 4x4 items for AWD. So far I've been right. The low range components fit inside the one speed case. The one speed encoder motor works the awd of the 236. The circuitry in the tccm plugs are identical pin wise. All I need is to document the pin to component wiring the rest has been direct replacement. No driveshaft issues no issues of any kind with fitment. So thanks for the vote of confidence and stay tuned. One way or another we're all gonna find out!
I do have one question tho. Where can I get wire that matches GM schematics. It would be nice to do but for sure I'm not gonna let it stop me!
2" body lift
S-10 rear leafs
NP236 tc
Soon:
Skid plates
rock rails
Captn.Crunch
Topics: 21
Images: 4
Re: np136 to np236
Postby gavio » July 19th 2015, 6:02pm
I get mine at pick and pull..... There's literally miles of it hiding under the dashboards of GM cars.... I don't always end up with exact matches, but usually close enough to keep track of what I'm doing... One time I pulled all the wire out from under the dash of a Blazer and couldn't believe how long the wire runs were - one whole bundle ran back and forth across the width of the car... The wiring running to the back of a cargo van is another easy grab for long color coded wires...
gavio
Topics: 77
Images: 4
Re: np136 to np236
Postby Lumpy » July 20th 2015, 12:31am
I think that's a very good idea. It's hard to find wire in anything but solid colors from regular, new wire retail outlets. They're usually limited to a handful of colors. To buy something with a stripe typically is obscenely expensive and/or requires buying huge spools of it. Getting it from a U-pull, along with some connectors, fuse panels, tie downs etc. Thar-R-Smarte.
Re: np136 to np236
Postby Leeann_93 » July 21st 2015, 1:23am
I have all the wiring diagrams and pinouts for the NV236 from the Blazer site if you need them.
Re: np136 to np236
Postby sixsix » July 21st 2015, 4:02am
Hmmmmm...
Some people around here are actually thinking!!!
And it looks good on em'.
What great ideas in this thread.
Mike
Well, after all... what would Banacek say ?... “Everything needs to change except the asshole culture and stupid way of life of the avg. antifa, BLM follower - slobs, cowards, killers w/o any thought that they, IN FACT, are now the Racists.”
Firing on 3 Cylinders (L5)
Topics: 37
Images: 1280
Re: np136 to np236
Postby Captn.Crunch [OP] » July 21st 2015, 12:10pm
To the P&P we go. Thanks for the ideas and support. Leeanne if I can't find what I need you'll be hearing from me. I've got summer camp with the Boy Scouts all next week so nothings gonna get done between now and when I get back. A week of molding the leaders of tomorrow while I sit in a comfortable chair by the lake. Rank has its privileges :wave:
2" body lift
S-10 rear leafs
NP236 tc
Soon:
Skid plates
rock rails
Captn.Crunch
Topics: 21
Images: 4
Re: np136 to np236
Postby Vandiction » August 5th 2015, 2:05am
subscribed
'05 Astro, AWD| 6.0 LQ4 cam'd/rods/lifters/ Slowhawk tuning| FLT 4L65 Stage VI| Yank Pro Truck 2800| Silverado SS X-fer case| 5" lift body/keys| Ride Rite| Rancho 9000XL| 245/70/16 AT| A/R 23 wheels| The SS Astro GM never made.
Vandiction
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Vandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full years
Topics: 13
Images: 36
Re: np136 to np236
Postby Meterpig » August 5th 2015, 3:25am
Speaking of wire, I have had good luck with Volvo's having quality 8 gauge wire for their electric fans. And...the yards don't charge me for it if I am buying something else.
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Re: np136 to np236
Postby racrx7 » August 10th 2015, 7:34pm
Just curious CC, why did you swap the 236 guts into the 136 case? Will the 236 not directly bolt up?
Thx,
Andre
2003 Astro 4X4
NP236/246 Hybrid Selec-Trac
4"lift
Dropped front IFS axle
255/70-16 BFG KO2's on 16x8 Fuel Revolvers.
racrx7
Years of Membership: racrx7 has been a member for 5 full yearsracrx7 has been a member for 5 full yearsracrx7 has been a member for 5 full yearsracrx7 has been a member for 5 full yearsracrx7 has been a member for 5 full years
Images: 2
Re: np136 to np236
Postby racrx7 » August 11th 2015, 3:29am
Hi Leanne, is there a link for the wiring and pin outs for the 236?
Thanks;
Andre
2003 Astro 4X4
4"lift
racrx7
Images: 2
Re: np136 to np236
Postby Corsemoto » August 11th 2015, 6:06am
racrx7 wrote:Just curious CC, why did you swap the 236 guts into the 136 case? Will the 236 not directly bolt up?
Thx,
Andre
The both use the same case and share most internals other than 2-speed parts.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Re: np136 to np236
Postby Captn.Crunch [OP] » August 11th 2015, 12:42pm
Thx,
Andre
There are two reasons I put the 236 guts in the 136 case. First of all, I wanted to make sure it would actually work. I didn't want to post something that I had not done and claim it would work. Also the 236 case was cracked. Didn't find out till I started cleaning it up prior to teardown. So I was" forced " to go the route I went. I was planning on a side by side comparison and interchangeability session while I had both cases open but the cracked front case on the 236 forced the installation of the NV ring as previously posted.
So yes I could have just bolted an np236 in but once again what fun would that be?
2" body lift
S-10 rear leafs
NP236 tc
Soon:
Skid plates
rock rails
Captn.Crunch
Topics: 21
Images: 4
Re: np136 to np236
Postby Leeann_93 » August 11th 2015, 1:02pm
racrx7 wrote:Hi Leanne, is there a link for the wiring and pin outs for the 236?
Thanks;
Andre
Not unless you're a member of blazerforum.com.
Re: np136 to np236
Postby Vandiction » August 11th 2015, 1:13pm
Update on how it's functioning?
Vandiction
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 13
Images: 36
Re: np136 to np236
Postby Captn.Crunch [OP] » August 11th 2015, 1:46pm
Vandiction wrote:Update on how it's functioning?
Update: it's going well thanks for asking. The transfer case is still being underutilized as a single speed awd. I have all the diagrams to wire everything together. I need to get to a P&P and grab a chunk of GM harness. I am also gonna need to see what I'm going to need to build the TCCM plug. I've actually been grabbing some OT at work so my play time is suffering a little
2" body lift
S-10 rear leafs
NP236 tc
Soon:
Skid plates
rock rails
Captn.Crunch
Topics: 21
Images: 4
Re: np136 to np236
Postby Leeann_93 » August 11th 2015, 11:09pm
Wiring diagrams and pinouts available here:
http://www15.zippyshare.com/v/En3chGpq/file.html
It is currently October 27th 2020, 10:19am
Date: Oct 10 '20
Time: 5:57pm
Comments: 22
Date: Oct 05 '20
Time: 1:43am
dit
in 4WD,AWD And Transfer Case
Comments: 17
Date: Sep 06 '20
Time: 11:02pm
Comments: 9
Date: Aug 16 '20
Time: 9:41pm
Date: Aug 05 '20
Time: 8:39am
cron
