BW4472 fit?
BW4472 fit?
Postby Vandiction [OP] » August 11th 2015, 2:12am
...into an '05? Is it a direct swap from the 136?
Mark mentioned it was the case in the Syclone/Typhoon and I'm finding it changed @1998.
Between that and the NVG149 (Silverado SS) I'm seeking the strongest case to fit the Astro.
'05 Astro, AWD| 6.0 LQ4 cam'd/rods/lifters/ Slowhawk tuning| FLT 4L65 Stage VI| Yank Pro Truck 2800| Silverado SS X-fer case| 5" lift body/keys| Ride Rite| Rancho 9000XL| 245/70/16 AT| A/R 23 wheels| The SS Astro GM never made.
Vandiction
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Vandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full yearsVandiction has been a member for 5 full years
Topics: 13
Images: 36
  • Does this rim size fit ? '01 Safari
    by Larry » May 5th 2020, 11:08pm in Wheels/Tires
    Last post by Larry View the latest post
  • ***SOS*** real axles don’t fit?
    by GutchDuts » May 14th 2020, 5:07pm in Rear-End
    Last post by GutchDuts View the latest post
    May 22nd 2020, 5:22am
    91
    October 29th 2020, 6:23pm
Re: BW4472 fit?
Postby Leeann_93 » August 12th 2015, 1:07am
It was the AWD case through '98 in all GMs.
It's in my '93 Astro and my '93 Bravada. Is it a tough case? Yep. Is it bulletproof? Nope.
I haven't had a single issue with NP136s in my '99 Safari or '02 Astro. I do have an issue with the BW4472 in my Bravada.
I also doubt it's a direct swap as there were changes in driveshaft heads and transmission outputs over the years. There's at least 2 version of the BW4472 just in GMs.
Re: BW4472 fit?
Postby Meterpig » August 12th 2015, 2:49am
I haven't found anyone who has done the swap other than myself..and currently that project is in planning phase. To make the swap work, at the minimum you will need the front and rear shaft from same astro you pull the case from. The input is identical from the 136 to the 4472. I have both in my garage.
Also, to remove the shafts you will need a special wrench that matches to external torx 12 and 14 (I think). You will use this tool maybe once to pull the front shaft at the transfer case. When you put it onto your new van, hit up fastenal for some flange bolts. I have heard a 12 point socket might work on pulling off the bolt. Judging by the look of the bolts I pulled off...indeed people have attempted. The right tool costs around 20 bucks.
The AWD light will illuminate. Deal with that in your fashion.
Enjoy no more transfer case drama-if your T case in good shape. Should the viscous clutch be in poor shape, that's a 400 dollar part in most places. Maybe less if you look around.
Leeann and I seem to be having running debate on the NP136. I think they are garbage fit for soccer mom duty but Leann believes they are fine. I have killed 3 in short order. After googling around, I found 2 people (one being leann) who have real problem with them. Maybe there are just a rash of problems out there with the old BW..I don't see it.
One other note, the front drive shaft on the BW is much bigger and beefier than the NP front drive shaft. I should post a photo. It's quite noticeable.
Hopefully my swap is going in this month.
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Re: BW4472 fit?
Postby HoosierDaddy » July 31st 2016, 2:21am
Reviving and old thread. I did a little junkyard scrounging today and found a couple AWD Astros. I was thinking that it might be a good idea to grab a spare transfer case when I come across an appropriate one. It appears that there are some variations of the early units with output splines. What years of van (or other AWD models) is a direct swap for my 1997?
Also is there any way to tell a good one from a bad one in a junkyard?
HoosierDaddy
Years of Membership: HoosierDaddy has been a member for 4 full yearsHoosierDaddy has been a member for 4 full yearsHoosierDaddy has been a member for 4 full yearsHoosierDaddy has been a member for 4 full years
Extra Info: LT AWD
It is currently October 29th 2020, 6:23pm
Comments: 14
Date: Oct 27 '20
Time: 5:06pm
Date: Oct 10 '20
Time: 5:57pm
Comments: 22
Date: Oct 05 '20
Time: 1:43am
dit
in 4WD,AWD And Transfer Case
Comments: 17
Date: Sep 06 '20
Time: 11:02pm
Comments: 9
Date: Aug 16 '20
Time: 9:41pm
