Video of my NP236/246 transfer case.
Postby racrx7 [OP] » December 3rd 2015, 12:01am
This is a short video of my 236/246 hybrid transfer case going thru the modes of operation. :dance:
2003 Astro 4X4
NP236/246 Hybrid Selec-Trac
4"lift
Dropped front IFS axle
255/70-16 BFG KO2's on 16x8 Fuel Revolvers.
racrx7
Years of Membership: racrx7 has been a member for 5 full yearsracrx7 has been a member for 5 full yearsracrx7 has been a member for 5 full yearsracrx7 has been a member for 5 full yearsracrx7 has been a member for 5 full years
Images: 2
  • New AWD Transfer Case
    by MechBob » August 5th 2020, 2:54pm in Parts/Accessories For Sale
    Last post by dcsleeperdcsleeper is online! View the latest post
    August 5th 2020, 3:55pm
  • Transfer case problems !!
    by Olivier02 » September 23rd 2020, 10:59pm in 4WD,AWD And Transfer Case
    September 25th 2020, 4:36pm
    22
    November 25th 2020, 6:43am
Re: Video of my NP236/246 transfer case.
Postby kennysmoke » December 3rd 2015, 12:17am
No video....
"Live Free Or Die" Image
kennysmoke
Blue Status (L2)
Blue Status (L2)
Topics: 68
Images: 7
Alias (AKA): kennysmoke
Extra Info: AWD Tow Pakage
Postby racrx7 [OP] » December 3rd 2015, 1:55am
Hmmm, shows up for me.
2003 Astro 4X4
4"lift
racrx7
Images: 2
Postby AstroWill » December 3rd 2015, 2:09am
It was showing up for me as a blank white space, but it's working now :)
Images: 443
Postby chevymaher » December 3rd 2015, 1:16pm
I fixed it,
Postby AstroWill » December 3rd 2015, 8:27pm
chevymaher wrote:I fixed it,
The man behind the curtain :) TY
Images: 443
Postby racrx7 [OP] » December 6th 2015, 10:20pm
Creeping along in 4Lo.
2003 Astro 4X4
4"lift
racrx7
Images: 2
Postby tanvanmanwithaplan » February 18th 2016, 1:20am
I can't post to the other forum because I've never registered and it requires moderator approval to join (dumb). For anyone reading this, I'm referring to this thread: http://goo.gl/4rRNhF Anyway, I am considering this build or at least a 236 swap since I've blown up my stock xfer case on my 2001 AWD Astro (only 30k miles since it was replaced). I've decided that the always on AWD is not for me since it's so picky about tire dimensions and it's not ideal for off roading, so for now I have my front driveshaft removed until I can put a 236 or 246 hybrid in.
Here are some articles about the 246 that I've stumbled across on the internet:
http://www.rsgear.com/articles/2005_09.pdf
http://www.rsgear.com/articles/2004_12.pdf
racrx7, do you have any comments on how difficult making the hybrid case is, particularly for someone who has never opened a trans or transfer case before? I am confident about being able to swap a 236 in and do the wiring (I'm a wiring/engineer-y type), but I am not so sure about doing some of the steps like calibrating/setting the clutch tolerances and such.
Also, do you have any more information like pinouts and such on how the wiring is done?
2001 AWD Astro LT 112k mi 4" lift inprog
tanvanmanwithaplan
Years of Membership: tanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full yearstanvanmanwithaplan has been a member for 6 full years
Topics: 13
Van Model Year: 2001
Extra Info: LT4.3LV6AWD
Postby racrx7 [OP] » February 22nd 2016, 1:36am
Tanvanman,
The link you posted from the "other" site pretty much covers what is needed to make a 236/246 hybrid case. All of the heavier duty guts from the 246 fits right in the 236 case with the exception of the front output shaft. It uses different front and rear bearings that will not work in the 236 case. But the 6 pinion planetary, 10 element clutch drum and the wider chain and sprockets fit perfect.
There's also an explanation on setting up the clutch packs in these cases on the other site. It's a very critical setting in order for it to work correctly. Also, do not use aftermarket clutches if your doing a rebuild. They are automatic transmission clutches and are too spongy to work correctly. I know because I used them and had to pull the case right back out due to binding and crow hopping. The OEM clutches are a harder material that won't bind up. Think motorcycle wet clutches. By design, the clutches have to be able to slip some when not engaged. AT clutches are ether on or off.
There's also a thread started on the other site on how to wire it all up.
:cheers:
2003 Astro 4X4
4"lift
racrx7
Images: 2
It is currently November 25th 2020, 6:43am
Date: Nov 15 '20
Time: 11:02pm
Comments: 14
Date: Oct 27 '20
Time: 5:06pm
Date: Oct 10 '20
Time: 5:57pm
Comments: 22
Date: Oct 05 '20
Time: 1:43am
dit
Comments: 17
Date: Sep 06 '20
Time: 11:02pm
