2003 awd Safari front end hum
Postby marky30 [OP] » March 11th 2016, 5:09am
Hi..I thinking about buying an awd Safari here in MI.It has 112K miles,looks nice.$1500 bucks.The seller say the front axle is leaking somewhere and it hums..From what I gather this could be the ring and pinion going.(i think im wrong about the ring and pinion..i think its the differential im thinking of).possibly from the lack of fluid from the leaky seal.What do you think about this purchase?Should these issues deter me from looking into this van?.Any input and opinions welcome..Thanks
marky30
Years of Membership: marky30 has been a member for 4 full yearsmarky30 has been a member for 4 full yearsmarky30 has been a member for 4 full yearsmarky30 has been a member for 4 full years
Extra Info: awd
Re: 2003 awd Safari front end hum
Postby WoodButcher » March 11th 2016, 1:12pm
Never heard of a ring and pinion in the front? but then I don't have AWD.
Regardless these vans are not hard nor expensive to repair. If your handy, buy a factory service manual and get under there. If your not a mechanic will be expensive.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 513
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby Leeann_93 » March 11th 2016, 10:06pm
The pinion seal goes bad and the case seal, less often, goes bad. Probably the pinion seal. It went bad in my '99.
If it's humming, probably easiest to find a front diff in a junkyard and swap them.
Postby fourwheelwheelie » October 11th 2016, 11:45pm
started new thread thanks.
fourwheelwheelie
Years of Membership: fourwheelwheelie has been a member for 4 full yearsfourwheelwheelie has been a member for 4 full yearsfourwheelwheelie has been a member for 4 full yearsfourwheelwheelie has been a member for 4 full years
Topics: 21
Images: 20
Alias (AKA): Jebbster
Extra Info: Tiara Conversion
It is currently October 29th 2020, 6:25pm
Comments: 14
Date: Oct 27 '20
Time: 5:06pm
Date: Oct 10 '20
Time: 5:57pm
Comments: 22
Date: Oct 05 '20
Time: 1:43am
dit
in 4WD,AWD And Transfer Case
Comments: 17
Date: Sep 06 '20
Time: 11:02pm
Comments: 9
Date: Aug 16 '20
Time: 9:41pm
