Transfer case drain plug torq
Postby Santier [OP] » May 25th 2016, 12:46am
Hi there anyone knows the torq for 1999 atro van AWD transfer case drain plug
Santier
Years of Membership: Santier has been a member for 4 full yearsSantier has been a member for 4 full yearsSantier has been a member for 4 full yearsSantier has been a member for 4 full years
Alias (AKA): Paul
Extra Info: 4.3L v6 AWD
  • Toggle switch torq conv. lockup PWM
    by M_a_t_t » August 21st 2020, 6:04pm in Automatic
    Last post by M_a_t_t View the latest post
    September 5th 2020, 10:36pm
  • Question What brand of drain plug kit do you use?
    by gavio » July 22nd 2020, 4:19am in Automatic
    Last post by AstroOafAdventurer View the latest post
    September 18th 2020, 3:29am
    December 4th 2020, 8:34am
Re: Transfer case drain plug torq
Postby Leeann_93 » May 25th 2016, 10:55pm
It's like 15. Just tight, not torqued. Tighten it more than that and you'll crack the case around it. The service manual says to use goo on it, too - I use plumber's thread goo my husband gave me. Permatex white or black, whichever pot I grab.
Postby Old Barney » May 26th 2016, 1:02am
I use Teflon tape and switch all my drain plugs out to brass plugs and make sure a wrench can be used instead of an extension on a shallow square hole in the plug to be wrung until it can't be removed. ALSO I do my own tightening. Most uneducated ding dongs at dealers will always over tighten every thing they touch from oil drain plugs to lug nuts. Nothing worse than trying to remove lug nuts that are stripped 40 miles from nowhere. Voice of experience here service manager got fired from loco dealership defending his monkeys who stripped the ones on my 1995 3/4 ton chevy pu. AND lost a customer and a few picking up their vehicles listening to my public display of dislike for the ding dongs. More to the story but not enough room here for the things the dealer did to other vehicles.
Old Barney
Years of Membership: Old Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full years
Topics: 23
Images: 47
Alias (AKA): Barney
Extra Info: awd
Postby Santier [OP] » May 26th 2016, 2:22am
Good to know , thanks I'll follow that
Santier
Alias (AKA): Paul
Postby timothy47130 » May 26th 2016, 2:33am
I use teflon tape made for natural gas line connections. Its the bright yellow stuff. Its quite a bit thicker than the plumbers teflon tape, its more elastic and stays stuck to the threads instead of getting all stringy when you tighten it like the white teflon tape.
Tim
1998 chevy astro mark III conversion with 125,000 miles
all stock besides-
dual exhaust
rear lifted 1" with s-10 leafs
10,000 lb capacity transmission cooler
corvette 2nd gear servo
Trans-go SK4L60E shift kit
5.7 Vortec swap on the way
timothy47130
Years of Membership: timothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full yearstimothy47130 has been a member for 5 full years
Topics: 41
Images: 7
Alias (AKA): Tim
Extra Info: mark III conversion
It is currently December 4th 2020, 8:34am
Date: Nov 15 '20
Time: 11:02pm
Comments: 14
Date: Oct 27 '20
Time: 5:06pm
Date: Oct 10 '20
Time: 5:57pm
Comments: 22
Date: Oct 05 '20
Time: 1:43am
dit
in 4WD,AWD And Transfer Case
Comments: 17
Date: Sep 06 '20
Time: 11:02pm
