Rattling/Rumbling sound from rear
Postby Astrodawn [OP] » March 14th 2017, 12:32am
A few years ago, my van started rattling terribly from the back (near the sliding door?) when idling and accelerating at low speeds.
A few weeks ago, it stopped.
Now it's been replaced by a low rumbling that happens under the exact same circumstances as the rattling. sometimes it's barely audible, but it's been happening more often and at higher decibels recently.
Is this something I should be concerned about?
[also i'm just guessing this should be in exhaust cause it seems like an exhaust thing. it's certainly exhausting to think about soooo]
Astrodawn
Years of Membership: Astrodawn has been a member for 4 full yearsAstrodawn has been a member for 4 full yearsAstrodawn has been a member for 4 full yearsAstrodawn has been a member for 4 full years
Topics: 22
Extra Info: RWD conversion
Re: Rattling/Rumbling sound from rear
Postby WimpTech » March 14th 2017, 12:43am
Probably rust/ exhaust related, someone will be along shortly...
WimpTech
Firing on 4 Cylinders (L5)
Topics: 39
Images: 322
Alias (AKA): =Wimpy=
Extra Info: Retired
Postby Astrodawn [OP] » March 14th 2017, 12:47am
Astrodawn
Topics: 22
Postby Mmusicman » March 14th 2017, 1:20am
Tailpipes are notorious for rattling... same for mufflers. The low rumble may just be a crack or hole in the exhaust system or muffler, probably from the rattling.
Just a guess...
Purple Status (L6)
Purple Status (L6)
Years of Membership: Mmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full years
Topics: 75
Images: 61
Postby M_a_t_t » March 14th 2017, 2:07am
Check your mounts for the tailpipe also.
As a temporary fix on mine I put a hose clamp on on, then of course I neglected to correct it until it fell off and started rattling. Put a rubber mount on it and it fixed my rattle.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Years of Membership: M_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full years
Topics: 29
Images: 113
Extra Info: cl rwd
Postby Astrodawn [OP] » March 14th 2017, 5:14am
this may be a stupid question (i ask a lot of these), but why does the exhaust rattle only under certain circumstances (i.e. why would it rattle only when idling)?
Astrodawn
Topics: 22
Postby Astro Pop » March 14th 2017, 6:08am
Uh... why haven't you crawled under there while it's idling to see where it's coming from? Take a pair of gloves and handful of rags and start feeling around.
Astro Pop
Years of Membership: Astro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full years
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby chevymaher » March 14th 2017, 11:01am
Astrodawn wrote:this may be a stupid question (i ask a lot of these), but why does the exhaust rattle only under certain circumstances (i.e. why would it rattle only when idling)?
The 6's are popcorn poppers. They are very rough idling. Once they are at a higher RPM the cylinder pulses are closer together and it is smoother. Smack around on the exhaust. and lower body panels. Where the plastic cladding is. That cladding is loose all along the bottoms. That will make a racket bouncing against the side of the body.
Topics: 91
Postby Leeann_93 » March 14th 2017, 4:06pm
When mine did this - and only when idling - it was the heat shield above the muffler/tailpipe. The pop welds popped and it was hanging down on the pipe.
I put it back up with 2 self-tapping screws, been silent since.
Topics: 45
Postby astronot » March 14th 2017, 4:10pm
Just thought I'd give my :2: I found a rattling on my 97 astro and it was the aluminum heat/splash guard that was the culprit. It's right above the exhaust just behind the sliding door and one of the anchors had come loose. You could either get new anchors or remove it. Just something to check.
astronot
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: astronot has been a member for 4 full yearsastronot has been a member for 4 full yearsastronot has been a member for 4 full yearsastronot has been a member for 4 full years
Topics: 20
Alias (AKA): Lefty
Extra Info: 1997 AWD 4.3
Postby Lumpy » March 20th 2017, 1:16am
I used to have a hard mount welded between the body metal and my exhaust. At a certain RPM it was like the pre-chorus on a dance-trance song. Raise it 20 RPMs and it's back to 1960s library quiet.
Cut the steel, replaced with rubber trucker's load straps that several here said would fail within eleven minutes. They're still just fine 109 years later.
... :obscene-buttred:
Grab it and shake it.
Years of Membership: Lumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full years
Postby sixsixsixsix is online! » March 20th 2017, 2:48am
Astrodawn wrote:A few years ago, my van started rattling terribly ... A few weeks ago, it stopped.
Now it's been replaced by a low rumbling that ...
Is this something I should be concerned about? ...
You COULD just let it go a "few years" - will probably work itself out.
Mike
"1 Nautilus died, BLM spawned, Antifa runs amok
- CRT & unions have taken schools by storm
THEN:
Not a single "Black" "Leader" condemns Black Crime
- White Supremacists get blamed for it all - they sure do get around"
Purple Status (L6)
Purple Status (L6)
Years of Membership: sixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full years
Topics: 39
Images: 1411
Postby Astrodawn [OP] » March 20th 2017, 3:44am
sixsix wrote:You COULD just let it go a "few years" - will probably work itself out.
that's the same philosophy i've used for my entire van. when the check engine light turned off a few years ago i knew she was immortal.
Astrodawn
Topics: 22
Postby sixsixsixsix is online! » March 20th 2017, 5:30pm
Astrodawn wrote:that's the same philosophy I've used for my entire van.
That's the spirit...
"Check Engine Light" Bulb probably just burned out - LOL.
Mike
THEN:
Purple Status (L6)
Purple Status (L6)
Topics: 39
Images: 1411
Return to Exhaust
It is currently July 23rd 2021, 8:12pm
Exhaust Forum
joeg
in Exhaust
Comments: 64
Time: 3:25am
joeg
in Exhaust
Comments: 64
Date: Jun 15 '21
Time: 7:28pm
in Exhaust
Date: Jun 11 '21
Time: 7:28pm
in Exhaust
Date: Jun 08 '21
Time: 11:03pm
Attached by: chevymaher
in Exhaust
Date: Mar 26 '21
Time: 10:53am
