Emissions Test Fail for my Astro Van
Postby ctwhyexit [OP] » August 26th 2017, 4:07pm
Chevy Astro 2001 Passenger van
4WD, ABS
My van failed its emission test last week giving me a sheet of paper with a reason,
Manifold Absolute Pressure/Barometric Pressure Circuit Low
I'm guessing I can go to a shop and show this and they might fix this issue for me but I wanted to know if there is anything related to this I should look into also as an inspection to see its related components are working as expected. Any ideas?
ctwhyexit
Years of Membership: ctwhyexit has been a member for 3 full yearsctwhyexit has been a member for 3 full yearsctwhyexit has been a member for 3 full years
Alias (AKA): CTW
Van Model Year: 2001
Extra Info: 4.3L
  • 1994 astro tail pipe clamp
    by xitxit is online! » September 14th 2020, 8:56pm in Exhaust
    Last post by dcsleeperdcsleeper is online! View the latest post
    September 14th 2020, 9:52pm
    32
    December 2nd 2020, 2:01pm
Re: Emissions Test Fail for my Astro Van
Postby plymouthcranbrook » August 26th 2017, 4:14pm
plymouthcranbrook
Years of Membership: plymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full years
Topics: 16
Extra Info: allwheel drive
Postby ctwhyexit [OP] » August 26th 2017, 4:20pm
Thanks, the code was P0107. I think this is the link. - https://www.obd-codes.com/p0107
ctwhyexit
Alias (AKA): CTW
Extra Info: 4.3L
Postby AstroWill » August 26th 2017, 4:22pm
Pretty easy to test the wiring, make sure you are getting your reference voltage, ground is good, connector is clean and not corroded. Or just spend the $35 and replace the sensor. It's super easy to replace and if that is all that it is, saves you the mechanics fee.
Images: 443
Postby ctwhyexit [OP] » August 26th 2017, 5:04pm
Is there a how-to manual on how to do this? I think there was a manual on this site that you indicated on my other thread. I will take a look at it also.
ctwhyexit
Alias (AKA): CTW
Extra Info: 4.3L
Postby AstroWill » August 26th 2017, 5:40pm
The GM Techline eSI is the ultimate manual, link in my signature. But replacing the sensor is 1 connector and it pops into place.
Images: 443
Postby ctwhyexit [OP] » August 26th 2017, 7:59pm
Thanks AstroWill. I will check this.
ctwhyexit
Alias (AKA): CTW
Extra Info: 4.3L
Return to Exhaust
It is currently December 2nd 2020, 2:01pm
Exhaust Forum
SheldonYoung
in Exhaust
Date: Oct 03 '20
Time: 2:03pm
Attached by: augidog
augidog
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:20pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 3:03pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 2:43pm
Attached by: Godron629
Godron629
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:29am
