2000 safari failed smog test. p0155 02 sensor heater circuit
Postby dapperdan7 [OP] » November 15th 2011, 1:20am
how would any of you proceed with diagnosis? i have 10 days on a permit to correct the problem. it is sensor 2 bank 2.
Questions: is this sensor hard to reach?
might it be something besides the sensor (circuit?)
i figured i would ask first before blowing money at the mechanic.
any help much appreciated
dan
dapperdan7
Years of Membership: dapperdan7 has been a member for 10 full yearsdapperdan7 has been a member for 10 full yearsdapperdan7 has been a member for 10 full yearsdapperdan7 has been a member for 10 full yearsdapperdan7 has been a member for 10 full yearsdapperdan7 has been a member for 10 full yearsdapperdan7 has been a member for 10 full yearsdapperdan7 has been a member for 10 full yearsdapperdan7 has been a member for 10 full yearsdapperdan7 has been a member for 10 full years
Topics: 9
Extra Info: awd
  • P0155 Bank 2 Senor 1 Code
    by stal023 » June 7th 2020, 4:08pm in Exhaust
    June 26th 2020, 9:57pm
  • 03 Safari P0141 Help. Which 02 sensor is this???
    by TQVanGuy » November 23rd 2020, 7:34pm in Exhaust
    November 26th 2020, 1:16am
    7
    62
    December 4th 2020, 8:32am
Re: 2000 safari failed smog test. p0155 02 sensor heater cir
Postby RECox286 » November 15th 2011, 2:03am
You are probably looking at a failed heater in the O2 sensor. 12 y.o. van, ? miles. If it were mine, I would replace all the O2 sensors. They do tend to wear out with age
I don't think you would have much trouble doing the job yourself. Make sure the female threads are OK after taking the old sensors out. (You may want to chase the threads.)
Insure that there is a bit of antisieze compound on the male threads before winding the new sensors in. (Most sensors come with some stuff already on them.)
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby dapperdan7 [OP] » November 15th 2011, 5:54pm
the sensors aint cheap so I'm going to have to get em one by one. 230,000 miles and she is a good runner. how much do faulty sensors affect the gas mileage? i imagine its a bit. thanx
dapperdan7
Topics: 9
Extra Info: awd
Postby RECox286 » November 15th 2011, 6:25pm
O2 sensors are the big player when the system is closed loop. Bad O2= open loop, PCM dumps more gas into the equasion. 230k miles ? I'm surprised that they work at all. Usually need changing
in the 150k mi range for best driveability. Sensors are not all that expensive unless you want Bosh, or Made in USA. All three sensors can be had from RockAuto.com in the $100 and up range,
depending on the brand. You may find an MPG improvement. Or the truck may pass emissions. Who knows ?
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby Corsemoto » November 17th 2011, 12:02am
Do yourself a favor and avoid sensor issues - Denso or Delphi, others can cause add'l codes imo. 02 sensor socket if you don't already have one.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby RECox286 » November 17th 2011, 2:22am
You can usually make out with a combination 7/8" wrench. Cut the connector off the old one to get it out with the box end, and then be careful putting the new
one in with the open end. I agree that the O2 wrench adapters and socket tools do make it easier, especially if you do this kind of work on a regular basis.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby dapperdan7 [OP] » November 17th 2011, 2:48am
thank you, gentlemen.
dapperdan7
Topics: 9
Extra Info: awd
Postby dapperdan7 [OP] » November 17th 2011, 2:54am
a quick question: i have 3 o2 sensors on my van.are they all the same?
alao, the denso o2 sensors are under 40$ i assumed they would be $100 apiece. am i missing something?
thx
dan
dapperdan7
Topics: 9
Extra Info: awd
Postby Leeann_93 » November 19th 2011, 9:44pm
They're all 3 the same and no, you're not missing something. $40 sounds right.
Postby RECox286 » November 19th 2011, 11:16pm
Look at the number of wires in the connector... 2 wires= no heater, 4 wires= heater. I have a combination of the 2 on my truck. $30 to $70 each is ballpark depending
on the brand. I prefer to use the Bosh sensors and have had no ill effects. Pick yer part, pay yer nickel.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Return to Exhaust
It is currently December 4th 2020, 8:32am
Exhaust Forum
SheldonYoung
in Exhaust
Date: Oct 03 '20
Time: 2:03pm
Attached by: augidog
augidog
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:20pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 3:03pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 2:43pm
Attached by: Godron629
Godron629
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:29am
