catalytic converter
catalytic converter
Postby Dan [OP] » March 7th 2009, 4:01am
will my 95 astro run well enough if I hollow out the catalytic converter until I can afford to install a new one? desperate in Washington
Dan
Years of Membership: Dan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full yearsDan has been a member for 12 full years
Re: catalytic converter
Postby astro355 » March 7th 2009, 4:51am
What is the problem with your catalytic convertor?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Big_kid » March 7th 2009, 4:52am
While I can't recommend doing this for legal reasons, I'll say that racecars don't run them and I'll leave it at that. :whistle:
Welcome aboard!
Firing on 7 Cylinders (L7)
Topics: 185
Images: 342
Extra Info: 2WD 5.7 V8
Postby astro355 » March 7th 2009, 4:59am
The problem with hollowing them out is that the converter is a larger diameter than the exhaust pipe. The exhaust traveling thru the pipe to converter and pipe again will go from a hi pressure to a low pressure and then hi again, that really messes with good flow. Not to mention the ricerish type noise that it will create.
astro355
Postby Farmer » April 4th 2009, 10:37pm
if you hollow it out run a piece of pipe that just slides through the inside and weld it in, no more expansion area. :D
'86 Astro shorty, rwd, 8 pass, 4.3 v6, Auto trans
'81 Bronco, 6" lift, 35" tires, Solid axle conversion
RESPECT THE VAN!!!
Farmer
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Farmer has been a member for 11 full yearsFarmer has been a member for 11 full yearsFarmer has been a member for 11 full yearsFarmer has been a member for 11 full yearsFarmer has been a member for 11 full yearsFarmer has been a member for 11 full yearsFarmer has been a member for 11 full yearsFarmer has been a member for 11 full yearsFarmer has been a member for 11 full yearsFarmer has been a member for 11 full yearsFarmer has been a member for 11 full years
Postby rev_les » April 20th 2009, 4:43am
I .. uhh.. sorta had a bad backfire on my '99 that blew my muffler wide open like a tincan once, before I figured out my coil was bad ( I was starting it with ether) *no redneck jokes here* lol.. anyway, I realized a while back that the cat's now like looking through straight pipe. It runs fine, it's a bit loud with my handbuilt single chamber muffler though. Oddly, I get no code 420 from it.HOwever, I have a new Magnaflow cat I need to get welded in now because here around Houston,it has to pass the sniffer...
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby nomo » April 20th 2009, 5:18am
I recently purchased a '95 Astro that the previous owner fancied as being somewhat of a hot rod. Thus, it has a 'high-flow' exhaust system with no cats. Sounds bad (too loud), but the little van runs OK and has no warning lights illuminated.
1995 Astro AWD CL w/rear air and "w" code engine
nomo
Years of Membership: nomo has been a member for 11 full yearsnomo has been a member for 11 full yearsnomo has been a member for 11 full yearsnomo has been a member for 11 full yearsnomo has been a member for 11 full yearsnomo has been a member for 11 full yearsnomo has been a member for 11 full yearsnomo has been a member for 11 full yearsnomo has been a member for 11 full yearsnomo has been a member for 11 full yearsnomo has been a member for 11 full years
Postby ihatemybike » April 20th 2009, 2:35pm
My '94 had the cat's internals break apart and occasionally clog my exhaust, broke the rest out and drove many months till I was given a '87and put it's cat on it. Little louder, but no problems.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Return to Exhaust
It is currently March 8th 2021, 9:38am
Exhaust Forum
SheldonYoung
in Exhaust
Date: Oct 03 '20
Time: 2:03pm
Attached by: augidog
augidog
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:20pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 3:03pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 2:43pm
Attached by: Godron629
Godron629
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:29am
cron
