Re weld tail pipe
Re weld tail pipe
Postby dnwong [OP] » September 30th 2013, 11:55am
Old tail pipe rusted and fell off. I bought a new pipe and clamped it to the muffler and 3 weeks later, the pipe breaks closer to the muffler. Now I don't have enough to réclamp the new tail section. Does this look like it can be rewelded?
1995 Chev Astro Conversion.
dnwong
Fueling (Full tank)
Fueling (Full tank)
Years of Membership: dnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full years
Topics: 28
  • 1994 astro tail pipe clamp
    by xit » September 14th 2020, 8:56pm in Exhaust
    September 14th 2020, 9:52pm
    9
    29
    October 28th 2020, 6:54am
Re: Re weld tail pipe
Postby chevymaherchevymaher is online! » September 30th 2013, 12:21pm
Pep boys sells little extention pipe for just this. Less than 10 bucks. If it will stick to the rusty stub left at the muffler your set. If not your not behind much.
Postby RECox286 » September 30th 2013, 3:47pm
Be honest and question how the inside of the muffler looks. Usually when this happens, it's time to make the donuts...
I've had this happen too many times to not know when the pipes and muffler are tired. I think you are headed for more
frustration in trying to do a repair rather than a replace [and be done with it.]
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby markmitch » September 30th 2013, 3:59pm
autozon sells a store brand turbo muffler for approx. 25 bucks
Firing on 5 Cylinders (L6)
Topics: 608
Images: 20
Extra Info: RS V8
Postby 97cargocrawler » September 30th 2013, 4:14pm
If you trim off that rusty 1/2" bit of pipe you may be able to weld to the existing weld seem there....but after having welded my own brand new pipes....I'd say that's a fools errand. It's difficult to weld new pipe so I can't imagine welding what you have there.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby dnwong [OP] » September 30th 2013, 7:09pm
markmitch wrote:autozon sells a store brand turbo muffler for approx. 25 bucks
Is the store brand a direct bolt on? Is this the one?
"http://www.amazon.com/Thrush-17715-Turbo-Muffler/dp/B00029J3AW/ref=pd_sim_sbs_auto_1"
I rather do a clamp on since I do not have access to welding tools.
Thanks,
dnwong
Fueling (Full tank)
Fueling (Full tank)
Topics: 28
Postby crusader1xxx » October 1st 2013, 3:50am
Sorry Mate...you need to replace that...Like the others have said, that muffler has seen better days and better to replace now then have it fall off on the highway...
crusader1xxx
Years of Membership: crusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full years
Topics: 25
Images: 16
Alias (AKA): Andy
Extra Info: RwD
Return to Exhaust
It is currently October 28th 2020, 6:54am
Exhaust Forum
SheldonYoung
in Exhaust
Date: Oct 03 '20
Time: 2:03pm
Attached by: augidog
augidog
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:20pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 3:03pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 2:43pm
Attached by: Godron629
Godron629
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:29am
