Time to replace muffler
Postby Got To Go [OP] » July 6th 2009, 5:49am
It's getting to be time for a muffler change. I want to get rid of the Giant piece of Junk under the van that GM calls a muffler. I don't want anything loud, but I want something light and reasonably quiet. Any suggestions would be appreciated. It's a 4.3 L. I am thinking about a MagnaFlo Muffler :think:
Got To Go
Years of Membership: Got To Go has been a member for 11 full yearsGot To Go has been a member for 11 full yearsGot To Go has been a member for 11 full yearsGot To Go has been a member for 11 full yearsGot To Go has been a member for 11 full yearsGot To Go has been a member for 11 full yearsGot To Go has been a member for 11 full yearsGot To Go has been a member for 11 full yearsGot To Go has been a member for 11 full yearsGot To Go has been a member for 11 full yearsGot To Go has been a member for 11 full years
Topics: 7
  • What is the stock OEM muffler length?
    by dcsleeperdcsleeper is online! » July 22nd 2020, 10:07pm in Exhaust
    July 22nd 2020, 11:10pm
  • Muffler rattling diagnosis
    by Godron629 » August 31st 2020, 3:26am in Exhaust
    Last post by K-TRON View the latest post
    September 18th 2020, 4:07am
    20
    November 27th 2020, 7:26am
Re: Time to replace muffler
Postby ghostrider1061 » July 6th 2009, 6:27am
flowmaster is a good choice. but i myself would go with cherry bomb. done rite it gives freer flow and not too loud.my children like the flow master and i like the cherrybomb. if you also want to replace your cat checkout http://www.cherrybomb.com and see what kinds of set ups they have. they could give you some ideas. :2: :rockon:
ghostrider1061
Years of Membership: ghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full years
Topics: 17
Alias (AKA): d j
Extra Info: 4.3L v-6 rwd
Postby Got To Go [OP] » July 11th 2009, 2:25am
I could n't see "onclick="window.open(this.href);return false;" But I am not very up on computers. I just want to replace that huge piece of metal they call a muffler with something that is lightweight and flows good without a lot of Noise. And Cheap :lol:
Got To Go
Topics: 7
Postby Ap577 » July 11th 2009, 8:12am
Flowmaster has the loudest in cab resonance, and is loud. louder than a magnaflow
The local exhaust shop probably has just replacement mufflers that are not stock and don't make a whole lot of noise
you could just do that and a hi flow cat
I have a super 44 flowmaster single to dual and it is LOUD, you could hear me coming from quite a way
Sounds like a v8 though everyone asks
In cab resonance is a big deal with flow masters too the are loud in cab as well
have 40 series on my dodge magnum and it is loud in cab too
also had true duals flowmaster on my 454 dually... way too loud next day changed for single magnaflow, still loud but way quieter
2000 Chevy Astro ls
20... 275/35/20
Flowmaster Super 44 dual exhaust
Magnaflow Highflow Cat
Hypertech PPE Max Energy Tuner
2 12" MTX Thunder subs
Rockford 750.1
Alpine 6x9s
Jensen 680watt 4 channel amp
55 watt 8k HID's
Blue LED License plate light
Ap577
Years of Membership: Ap577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full yearsAp577 has been a member for 12 full years
Postby guyonearth » July 11th 2009, 4:43pm
I use a dynomax 27" turbo muffler that isn't too loud, but in retrospect I probably would have kept the stock unit. If you don't want "loud" then you probably want a stock-type unit.
guyonearth
Years of Membership: guyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full years
Topics: 5
Alias (AKA): DeanC
Postby Got To Go [OP] » July 12th 2009, 6:03am
I like the dynomax 27" turbo muffler idea. Should flow pretty good and not too loud. Thanks. Jack
Got To Go
Topics: 7
Postby mattsrevenge » July 16th 2009, 9:29pm
im after a muffler that doesnt rust out. my 96 has had 4 mufflers on it since my dad has owned it, and now its my turn to change.
idk really about the sound, just something quality?
have you had troubles with the exh rusting out? usually dies @ exit port on the muffler, or at the drain hole.
ive seen some walker, and flowmasters for ~70$ +, but would like experienced folks to chime in!
thanks
96 astro conversion
98 crown vic p71
mattsrevenge
Years of Membership: mattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full years
Extra Info: 2wd conversion
Postby astro355 » July 17th 2009, 12:28am
If you want a muffler that doesn't rust, you can't get a factory replacement from any of the fast food places. Remembering that the catalytic converter turns some emissions into water, any of the cheap and thin mufflers will not last longer. Even if the sound stayed the same, you would still be better off putting a flowmaster, magnaflow, etc just because they are built to last.
But on another note, have you thought about sidepipes? :mrgreen:
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Mr_Bowtie » July 17th 2009, 1:48am
Get a stainless steel muffler and be done with it. Magnaflows are SS I believe. 8-)
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby jeff's93astro » July 17th 2009, 2:32am
mine van has a 40 series flowmaster with duels out the back and it has a very nice mellow sound
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby Got To Go [OP] » July 17th 2009, 3:34am
MagnaFlow makes a stainless muffler and I don't think the price is to bad. That's what I will put on when I get time. GTG :)
Got To Go
Topics: 7
Postby traxxasmike » July 17th 2009, 7:37am
Edelbrock makes some of their mufflers in stainless too! Give them a listen.
1994 Chevy Astro, CPI Vortec engine, rebuilt transmission with high energy clutches and kevlar bands. Fairbanks Billet 2-4 apply servo. Cold air intake. 3" high flow cat, edelbrock sdt muffler. 3.73 gears. Mattress in the back!
traxxasmike
Years of Membership: traxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full yearstraxxasmike has been a member for 11 full years
Extra Info: 4.3L CPI V6 RWD
Return to Exhaust
It is currently November 27th 2020, 7:26am
Exhaust Forum
SheldonYoung
in Exhaust
Date: Oct 03 '20
Time: 2:03pm
Attached by: augidog
augidog
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:20pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 3:03pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 2:43pm
Attached by: Godron629
Godron629
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:29am
