tail pipe vibration
tail pipe vibration
Postby 01safari [OP] » August 17th 2009, 1:35am
A while back I had an exhaust leak between the right side manifold and the crossover pipe. I snugged the nuts up and the noise went away. Lately the tailpipe vibrates enough to make alot of noise inside the van. It is really bad with the A/C on. I am not sure if it is an exhaust issue or just engine vibration getting amplified? I thought there was a service bulliten about it the exhaust, but can't find it.
any one else hving this issue?
01safari
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: 01safari has been a member for 11 full years01safari has been a member for 11 full years01safari has been a member for 11 full years01safari has been a member for 11 full years01safari has been a member for 11 full years01safari has been a member for 11 full years01safari has been a member for 11 full years01safari has been a member for 11 full years01safari has been a member for 11 full years01safari has been a member for 11 full years01safari has been a member for 11 full years
Topics: 13
Extra Info: RWD
  • 1994 astro tail pipe clamp
    by xit » September 14th 2020, 8:56pm in Exhaust
    September 14th 2020, 9:52pm
    7
    90
    October 28th 2020, 6:23am
Re: tail pipe vibration
Postby 'cudapaul » August 17th 2009, 1:39am
Are you sure that it is the exhaust pipe?
There is a heat shield on the passenger side of the trans that is notorious for rattling at certain RPM's, usually just above idel. Might want to check it.
'cudapaul
Years of Membership: 'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby Big_kid » August 17th 2009, 3:24am
'CudaPaul is right. My old S10 had that rattle, the heat shield over the converter had developed a crack. My fix was to bend the two halves away from each other. That would work for a while, I did it two or three times. I eventually drilled a hole to keep it from spreading. That lasted for some time too. Eventually I cut off one corner of it(I think).
Firing on 6 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby 01safari [OP] » August 18th 2009, 2:50am
Yes, it is the tailpipe. you can watch it vibrate. Noise goes away if you rest your foot on it. It is really bad in drive with the air on during a stoplight. Goes away if I slip it in neurtal.
01safari
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 13
Extra Info: RWD
Postby Mr_Bowtie » August 18th 2009, 6:51am
Have you looked to see if the rubber hangers are still in place for the exhaust?
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby 01safari [OP] » August 19th 2009, 1:06am
hangers are still there...
I see you are a CVPI fan! They are one of my favorites to "test drive", especially the unmarked ones.
:layrubber:
01safari
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 13
Extra Info: RWD
Postby Mr_Bowtie » August 19th 2009, 2:03am
Hmmmmm.....maybe have someone put the Van in gear and check it out while the RPMs are lowest. Should be really obvious you would think...
I was a big CVPI freak before I found my love of the Astro/Safari Vans. :P
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby ritous1 » August 23rd 2009, 7:57am
my 99 rwd has the same exact problem. I took it in for inspection last year and they told me it was the catalytic. Still don't know if I believe them since I can literally stop it with one finger on the tailpipe. I just went ahead and bought a whole new exhaust system from the manifold back. Haven't had it installed yet, so I'll have to keep you posted on the results.
99 rwd 139k miles
paxton supercharger
bosch 36lb injectors
walbro 255 pump
aluminum radiator & dual efans
accel billet distributor
crane hi-6 ignition & race coil
magnaflow cat/ypipe
doug thorley dual exhaust
sonnax shift kit & vette servo
ritous1
Years of Membership: ritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full yearsritous1 has been a member for 12 full years
Topics: 31
Postby jeff's93astro » August 23rd 2009, 6:28pm
i had same problem something about the stock gm exhaust with rusting out and causeing a vibration. i went back with stainless steel pipe no cat with single in dual out flowmaster super 40 muffler and thats been about 2 years and there is no vibration anymore
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby 01safari [OP] » August 24th 2009, 12:29am
I probably won't look at it for a couple of weeks. Since I only drive 1.5 miles each way to work, it's not that big of a deal. Definately before winter.
01safari
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 13
Extra Info: RWD
Return to Exhaust
It is currently October 28th 2020, 6:23am
Exhaust Forum
SheldonYoung
in Exhaust
Date: Oct 03 '20
Time: 2:03pm
Attached by: augidog
augidog
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:20pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 3:03pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 2:43pm
Attached by: Godron629
Godron629
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:29am
