tail pipe exit location
Postby astro-nomer [OP] » June 5th 2010, 3:45pm
so...
what I thought might be a muffler issue that a limb apparently triggered yesterday proves to be
only the tailpipe broken at the muffler (it seems much older than the rest of the exhaust)
so lucky me, I have a large piece of appropriately sized exhaust pipe to chop from.
it looks like I can pull-off chopping an accurate replacement piece from it and just weld the hooks on...
but since Im kinda liking the slight added rumble, is there any issues associated with exiting before the
rear tire as opposed to after?
I know going out the back is a CO2 no-no, so I thought Id check your inputs on this location before chopping
my extra piece.
(no emissions test here, an apparently almost no restriction on volume considering the "G's rides" )
thanks!
94 RWD Astro "Z" shorty panel
astro-nomer
Years of Membership: astro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full yearsastro-nomer has been a member for 11 full years
Topics: 7
  • 1994 astro tail pipe clamp
    by xit » September 14th 2020, 8:56pm in Exhaust
    September 14th 2020, 9:52pm
  • Can't find EGR valve location
    by mutable » June 1st 2020, 3:15am in Exhaust
    Last post by mutable View the latest post
    June 7th 2020, 9:56pm
    84
    October 28th 2020, 6:17am
Re: tail pipe exit location
Postby Leeann_93 » June 5th 2010, 3:48pm
If your van is a passenger, exiting in front of the rear tire is a big no-no. You'll pull exhaust into the passenger compartment.
Exiting out the rear isn't a no-no if the tailpipe extends just past the bumper. Plenty of vehicles come from the factory that way.
Postby astro-nomer [OP] » June 5th 2010, 3:58pm
well, there are almost never any passengers back there... no seats either... and no window... and the bottom slider track is pretty much
gone and so the slider almost never gets opened.
does any of this make it less of a no-no? haha
if so, would I be helping myself out by making sure the slider seal is nice and tight?
THANKS!
astro-nomer
Topics: 7
Postby Big_kid » June 5th 2010, 6:19pm
I'd still keep it aft of the wheel. Even if there's nobody in the back, the air back there still mixes with the air up front.
Firing on 6 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby AstroCan » June 5th 2010, 7:42pm
Well I heard if your exhaust exits under your car the gases can puddle up there and if someone throws his cigarette under it it can explode. but that is probably very rare.
2004 Astro LS AWD
AstroCan
Years of Membership: AstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full yearsAstroCan has been a member for 10 full years
Topics: 59
Extra Info: LS
Postby astro-nomer [OP] » June 5th 2010, 9:55pm
well as it turns out I would have had to do almost a u turn with the pipe to get the side exit happening anyhow....
and my extra, reasonably new piece of pipe is nowhere near working with just a little chopping...
so I hacked and tacked and have a replacement piece that will hopefully last untill I've got some $$$
for the real-deal.
Its not real pretty or else I would take a pic... but is good experience in the exhaust dept...
and notably better than the shot-gun bubblegum business the last hobo did on there.. haha
thanks folks for your input and keeping me alive and breathing!
astro-nomer
Topics: 7
Postby Big_kid » June 6th 2010, 1:01am
What I had on mine wasn't pretty, wasn't professional, but it got the job done for almost 2 years. I had an intermediate pipe, muffler, and part of a tailpipe from an E250 stuffed in there, and the rest of the pieced together tailpipe exited out back. I took it to a shop a few months ago, they welded the intermediate to the cat (was very poorly clamped before) and fabbed a new tailpipe for $80. It's pretty quiet, and it doesn't fill the van with fumes. I'm happy.
Topics: 185
Images: 333
Postby astro-nomer [OP] » June 6th 2010, 3:09am
cool.
so I ended up with it exiting at almost a perfect 45 degree angle
about an inch below and an inch beyond the very corner of the bumper.
I actually like where it is now better...
but Im guessing its not gonna last me for more than another year....
dear gods I hope it does'nt need to!!
but I hope I can get it the same way when I replace the whole shabangh.
astro-nomer
Topics: 7
Postby Zebediah III » June 8th 2010, 4:35am
I think that's how I'm doing mine. My muffler comes in tomorrow and I will have the pipes exit pointing down a bit and back. Just sticking past the bottom of the quarters maybe 3/4". I don't like pipes poking out under the bumpers. I have the very short van, so from the wheel well to the bumper is inches so I'm sticking them out just aft of the aft edge of the wheel well and pointing 45 degrees down and out slightly. They really won't be visible, or at least not noticeable. I did one this way a few years ago and liked it except that both pipes came out the right side.
Zebediah III
Images: 16
Extra Info: 383 Crate Motor
Postby $uperJoe » June 8th 2010, 4:38am
nomer is there any pics of this. thats exactly what i am doing on my van and had to make a custom receiver hitch so i would have room. any tips before i start on my exit?
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
Postby astroturf » June 8th 2010, 2:05pm
Zebediah III wrote:I think that's how I'm doing mine. My muffler comes in tomorrow and I will have the pipes exit pointing down a bit and back. Just sticking past the bottom of the quarters maybe 3/4". I don't like pipes poking out under the bumpers. I have the very short van, so from the wheel well to the bumper is inches so I'm sticking them out just aft of the aft edge of the wheel well and pointing 45 degrees down and out slightly. They really won't be visible, or at least not noticeable. I did one this way a few years ago and liked it except that both pipes came out the right side.
Welcome Aboard Zeb. As you have prolly read, we like pix... We also have a saying around here that goes...
Without a Pic... It didn't Happen.
So post em up. And Again Welcome. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby astro-nomer [OP] » June 8th 2010, 10:22pm
$uperJoe- considering your build, Im the LAST guy to be giving YOU advice! haha
this was totally a redneck frankenstein hack-and-patch fix for me and since it was assembled from
5 parts there was alot of potential adjustment.
the angle of the last bend in the old pipe I was using was right, so some extentions before and after landed it in the right place.
"without pics it did'nt happen"
yeah... there are some things Im happier pretending DID NOT happen as far as showing them off. hahaha
astro-nomer
Topics: 7
Postby $uperJoe » June 8th 2010, 10:47pm
i understand that. since your van is regular height if anyone is inclined to look under there and still have the mustard to say anything to you about how it looks just tell them to look again and casually floor the van in reverse. i bet they would not say much after that. hahaha J/K. i think i found a way to get it done today. the exhaust shops in my area want 150 bucks for 2 tail pipes. less than 10 feet total. i will try it myself first for about 30 bucks and see how it comes out
$uperJoe
Topics: 59
Postby Zebediah III » June 9th 2010, 3:39am
I finished this today. Life got in the way so I took longer than I expected but I got it the way I wanted it. Hope the pictures show up
I'll drive this a while then take the headers off and get them coated. They fit really well. I used 2-1/4" because my 2-1/2" die is at the airport and I didn't want to drive over there and find it. I used a Flowmaster 50 which I hope I don't regret. It's not very loud, but if it gets much louder with time it's coming off.
Zebediah III
Images: 16
Postby $uperJoe » June 9th 2010, 4:13am
good stuff. ill post mine when im done as well. i like how there side by side for a while.
$uperJoe
Topics: 59
Return to Exhaust
It is currently October 28th 2020, 6:17am
Exhaust Forum
SheldonYoung
in Exhaust
Date: Oct 03 '20
Time: 2:03pm
Attached by: augidog
augidog
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:20pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 3:03pm
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 2:43pm
Attached by: Godron629
Godron629
in Exhaust
Comments: 38
Date: Sep 02 '20
Time: 4:29am
