My van keeps throwing a code for my o2 sensor Bank 1 Sensor 2, i changed the sensor between the cat and muffler didn't change? This is on my 97
I've searched and it doesn't say any more then the scanner tells mewebcat said:Check your wiring ,, also google your code and see what other info you might find
Thank you, I so replaced the wrong one, any ideas on getting those out on the passenger side sensor 1 & 2, i bearly can get my hands up thereAstroplane said:Bank 1 Sensor 2 is just forward of the cat. AKA pre-cat O2.
Bank 1 Sensor 3 is after the cat. AKA post-cat O2
Bank 1 Sensor 1 is drivers' side.
Bank 2 Sensor 1 is passenger side.
This applies to '96 and '97 M/L.
the code was P0140Astroplane said:Which code? There are a variety of O2 sensor sockets and crowsfoot wrenches available. Leann has a pic on here of a great setup.
Thats the one between the cat and mufflerkylegap said:Someone has a picture or drawing of Bank 1 Sensor 3 location???
Ok, so it's not showned on this picture?:grandamle91 said:Thats the one between the cat and mufflerkylegap said:Someone has a picture or drawing of Bank 1 Sensor 3 location???
no that picture is wrong, theres only one o2 on the drivers and 3 on the passengers sidekylegap said:Ok, so it's not showned on this picture?:grandamle91 said:Thats the one between the cat and mufflerkylegap said:Someone has a picture or drawing of Bank 1 Sensor 3 location???
whats the story of this Astro ? it looks like it has photo shopped wheels on it.grandamle91 said:no that picture is wrong, theres only one o2 on the drivers and 3 on the passengers side
ya its the closest one to the rearkylegap said:Ok, so it the third one on the passenger side front to rear?
Where is Bank 1 sensor 3 on your drawing?grandamle91 said:ya its the closest one to the rearkylegap said:Ok, so it the third one on the passenger side front to rear?
dont know why that picture showed up
after the catkylegap said:Where is Bank 1 sensor 3 on your drawing?grandamle91 said:ya its the closest one to the rearkylegap said:Ok, so it the third one on the passenger side front to rear?
The dealer told me there is a problem with Bank 1 Sensor 3.webcat said:kylegap wrote "Where is Bank 1 sensor 3 on your drawing? "
grandamle91 wrote "after the cat "
Webcat wrote
"In this picture theres no Bank 1 sensor 3 ,,, but there is a Bank 2 sensor 3 ,,, is that what you meant to say? "
i replace all mine on bank 2 with the same bank 1 had a flat connector and bank 2 had a sqaurekylegap said:Another question is, when I buy it, I order a front sensor or a rear?
Which one on what page:
Front:
http://www.autopartsway.ca/autoparts2/i ... olet~Astro 4.3 V6 Standard Cargo Van Base AWD~240666~240666~22~keysensor
Rear:
http://www.autopartsway.ca/autoparts2/i ... olet~Astro 4.3 V6 Standard Cargo Van Base AWD~240666~240666~30~keysensor
Ok, and can you tell which one is Bank 1 Sensor 3? This is the main question on this thread and it's never been answered clearly.grandamle91 said:i replace all mine on bank 2 with the same bank 1 had a flat connector and bank 2 had a sqaurekylegap said:Another question is, when I buy it, I order a front sensor or a rear?
Front:
Rear:
