Questions about the RPO codes from our new van:
Postby astrometalvan [OP] » September 18th 2016, 6:15pm
HOME RUN!!! GT4 AND G80 !!!! :driving:
I have some codes I couldn't find explanation for:
1. EVA.. something to do with emissions and the evap system?
2. R6Y..I found nothing
3. SLL...I found nothing
4. 6XB and 7XB... something about computerized suspension? :confused:
What is "special heavy trailering equipment"?
Thanks for any clarification.
2000 Astro LT AWD 4.3L W 4L60E GT4 G80
96 Astro LT 2wd 4.3L W 4L60E
92 S10 2wd reg/short 2.8 R T-5
93 S10 Ex cab/short 4.3L Z 700R-4
88 SeaRay Seville 21' cuddy Mercruiser MCM205 4.3L/4BBL-98Alpha1
91 S10 Reg/short 4.3L Z MY2 GT5
astrometalvan
Years of Membership: astrometalvan has been a member for 8 full yearsastrometalvan has been a member for 8 full yearsastrometalvan has been a member for 8 full yearsastrometalvan has been a member for 8 full yearsastrometalvan has been a member for 8 full yearsastrometalvan has been a member for 8 full yearsastrometalvan has been a member for 8 full yearsastrometalvan has been a member for 8 full years
Topics: 30
Images: 6
Alias (AKA): baddad71
Extra Info: LT 4.3 W AWD
Re: Questions about the RPO codes from our new van:
Postby paulo57509 » September 18th 2016, 7:53pm
EVA = TEST DVT, EVAP EMISSION REQUIREMENT EVAP EMISSIONS REQUIRED(EVA)
R6Y = CONTROL, SALES ITEM NO. 24 (the only reference I was able to find)
SLL = SOLD ORDERS SOLD ORDER(SLL)
I believe a computer program or algorithm is used to select spring rate, height, etc. using vehicle weight, equipment and options combos :shrug:
6XB = COMPONENT FRT LH COMPUTER SEL SUSP (6XB) SUSP(6XB)
7XB = COMPONENT FRT RH COMPUTER SEL SUSP (7XB) SUSP(7XB)
This is the only reference I've found to "special heavy trailering equipment". I think it means that there's mounting points for a Reese hitch.
Z82 = TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82)
Reese Hitch: https://www.reese-hitches.com/
paulo57509
Firing on 7 Cylinders (L1)
Topics: 24
Extra Info: RWD
It is currently October 29th 2020, 3:48am
Technical Information Forum
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
Date: Apr 14 '20
Time: 5:32am
Attached by: augidog
augidog
Date: Jan 24 '20
Time: 2:28am
