P0440 Evap Code 02 Astro
Postby Mr Bones [OP] » March 14th 2011, 10:21pm
Will the Vapor Canister Purge Valve being bad or leaking cause the P0440 Evap code? And yes i put a new gas cap and the code came back :screaming:
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: Mr Bones has been a member for 10 full yearsMr Bones has been a member for 10 full yearsMr Bones has been a member for 10 full yearsMr Bones has been a member for 10 full yearsMr Bones has been a member for 10 full yearsMr Bones has been a member for 10 full yearsMr Bones has been a member for 10 full yearsMr Bones has been a member for 10 full yearsMr Bones has been a member for 10 full yearsMr Bones has been a member for 10 full years
Topics: 9
Alias (AKA): Papa Smurf
Extra Info: LS 4.3L V6 RWD
Re: P0440 Evap Code 02 Astro
Postby Leeann_93 » March 14th 2011, 10:45pm
Postby Mr Bones [OP] » March 15th 2011, 8:16pm
Leeann_93 wrote:http://www.obd-codes.com/p0440
In short, yes.
That's my luck :banghead: I ordered a new one from O'Reilly i should have it in about a week it was only 21.99 + shipping not bad the dealer wanted $58.00 for it :eek: so O'Relly was the better choice.Thanks for you help :cheers:
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby Mr Bones [OP] » March 17th 2011, 2:03am
I put the new Vapor Canister Purge Valve in today a replaced the two plastic lines and reset the engine light i hope this does the job. :pray:
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby Mr Bones [OP] » March 17th 2011, 9:01pm
The engine light is back on it going in to the shop Monday for they can do the smoke test to find the link in the evap :(
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby Mr Bones [OP] » March 22nd 2011, 7:51am
the shop did the smoke test today and i have a bad leak on the top of my fuel tank so it got to come out to be fixed. Does any here have pictures of the top a 2000 to 2005 fuel tank i can use as a reference?
la tienda hizo la prueba de humo hoy y tengo una fuga mal en la cima de mi depósito de combustible por lo que consiguió salir a fijarse. ¿Cualquiera aquí tiene fotos de la parte superior un tanque de combustible de 2000 a 2005 que puedo usar como referencia?
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby chevymaher » March 22nd 2011, 10:45am
2002 astro fuel tank.jpg (102.08 KiB) Viewed 8518 times
Topics: 91
Postby Mr Bones [OP] » March 24th 2011, 6:37am
chevymaher wrote:
Thank You
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby Mr Bones [OP] » April 3rd 2011, 12:22am
Fixed the fuel pump o-ring was leaking bad.
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby chevymaher » April 3rd 2011, 12:24am
sweet glad it fixed :banana:
Topics: 91
Postby Mr Bones [OP] » April 3rd 2011, 4:54am
This was a fun job.I ran my fuel tank under E you would think there will only be two or three gallons of gas right? and it would not weigh that much so i took off the straps let down the jack and try to grab a hold of it and weigh a ton :confused: so i get it out and take out the fuel pump out and there like 5 or 6 inches of gas in it :eek: so i empty it out so i can clean it and there was 11.1/2 gallons in the tank. So is that right ? or is my sending assembly bad? :shrug:
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby chevymaher » April 3rd 2011, 5:57am
Mr Bones wrote:This was a fun job.I ran my fuel tank under E you would think there will only be two or three gallons of gas right? and it would not weigh that much so i took off the straps let down the jack and try to grab a hold of it and weigh a ton :confused: so i get it out and take out the fuel pump out and there like 5 or 6 inches of gas in it :eek: so i empty it out so i can clean it and there was 11.1/2 gallons in the tank. So is that right ? or is my sending assembly bad? :shrug:
sounds like it.When I did my fuel pump when it said empty tank was pretty much empty.Barely any in it sloshing around.Never measured it but i doubt there was more than a couple gallons.when you looked in you could just see some at the bottom.
Topics: 91
Postby Gary » April 3rd 2011, 6:33am
It's advised to not let these vans run under a 1/4 because the fuel pumps use the fuel to help cool them.So it might be a benefit to you the way the float is set that you didn't know about until now.When I did my fuel pump I too had about 1 1/4 gallons left at E.I don't think you would want it set so E is E if you where stuck somewhere trying to get to the gas station.I don't know for sure,but I would think GM sets those floats for alittle reserve. :think:
Gary
Dearly Departed
Firing on 4 Cylinders (L3)
Topics: 136
Extra Info: high top
Postby Mr Bones [OP] » April 3rd 2011, 7:37am
I think might know what the problem is i look up the part number (E3940M) of the fuel pump assembly that in my tank and it for a 97-99 astro and the P/N for my 2002 is E3506M.
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby Leeann_93 » April 3rd 2011, 2:51pm
That would be a problem. The 97-99 Astro/Safari has a 25 gallon tank. You have a 27 gallon tank. I assume the dimensions are different, because that shouldn't make E be 11½ gallons...but it's also possible the sender has the sulphur coating on it. GM has fuel injection cleaner that claims to clean off those sulphur deposits and prevent them from coming back and now Techron claims to clean off the sulphur deposits as well.
Postby Mr Bones [OP] » April 4th 2011, 4:50am
The fuel pump / sending assembly is new i will replace it with the right assembly later this summer. :chevy:
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby 96Blastro » April 4th 2011, 10:20am
Man I remember when my stock fuel pump went out I thought I had bad gas lol. Had a half tank when I dropped it and it weighed a grip. Boy was I messed up on fumes that day.
96' RWD Blastro LS,
Short Ram Intake,
Borla Turbo XL Muffler,
3 Kicker CompVR 12's,
1800 watt Monoblock Amp,
Pioneer 3200ub H.U.
I love my Blastro!
96Blastro
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: 96Blastro has been a member for 10 full years96Blastro has been a member for 10 full years96Blastro has been a member for 10 full years96Blastro has been a member for 10 full years96Blastro has been a member for 10 full years96Blastro has been a member for 10 full years96Blastro has been a member for 10 full years96Blastro has been a member for 10 full years96Blastro has been a member for 10 full years96Blastro has been a member for 10 full years
Images: 13
Alias (AKA): Wall
Van Model Year: 1996
Extra Info: LS Rwd with LT Seats
Postby Mr Bones [OP] » April 4th 2011, 4:13pm
96Blastro wrote:Man I remember when my stock fuel pump went out I thought I had bad gas lol. Had a half tank when I dropped it and it weighed a grip. Boy was I messed up on fumes that day.
Pulling the fuel tank out again is something i am not looking foreward to again :banghead:
Mr Bones
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 9
Postby Astro-logist » July 13th 2012, 12:34pm
I know this topic is old but speaking of the reserve level in the tank....a previous poster was right about a reserve.
My Wife is an expert on this as she runs her tank on friggin empty all the time, almost every time.
She claims she can get an extra 18-20 miles once the low fuel light comes on.
Now if I can just get her to fill up at 1/4 tank level it would be a minor victory.
I am going to watch HER replace the next fuel pump!
Astro-logist
Years of Membership: Astro-logist has been a member for 9 full yearsAstro-logist has been a member for 9 full yearsAstro-logist has been a member for 9 full yearsAstro-logist has been a member for 9 full yearsAstro-logist has been a member for 9 full yearsAstro-logist has been a member for 9 full yearsAstro-logist has been a member for 9 full yearsAstro-logist has been a member for 9 full yearsAstro-logist has been a member for 9 full years
Extra Info: 4.3 RWD.
It is currently April 18th 2021, 3:48am
Technical Information Forum
nsfkid1
Date: Apr 03 '21
Time: 9:22pm
Attached by: LumaWJ
LumaWJ
Comments: 21
Date: Mar 18 '21
Time: 8:54am
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
