What are timing specs for 88 Astro with 4.3L V-6
Postby RJAC [OP] » July 26th 2011, 2:41pm
What is the procedure and specifications for setting the ignition timing for a 1988 Chevy Astro with the 4.3 L engine. I have no sticker under the hood with any information. I have been told to disconnect a wire somewhere but I need to know which wire and also the timing setting in degrees before 0.
Thanks, Eric
[email protected]
RJAC
Years of Membership: RJAC has been a member for 9 full yearsRJAC has been a member for 9 full yearsRJAC has been a member for 9 full yearsRJAC has been a member for 9 full yearsRJAC has been a member for 9 full yearsRJAC has been a member for 9 full yearsRJAC has been a member for 9 full yearsRJAC has been a member for 9 full yearsRJAC has been a member for 9 full years
Extra Info: 1988
Re: What are timing specs for 88 Astro with 4.3L V-6
Postby 93xtmoney » July 29th 2011, 3:29pm
I don't know if anyone emailed him, but was just checking to see if anyone helped him out.
93 Safari XT awd slt with the GMC touring package a.k.a. Money Machine
5000K foglights, type R headlights 7000K, clear corners, APC black euro tail lights,
93xtmoney
Years of Membership: 93xtmoney has been a member for 9 full years93xtmoney has been a member for 9 full years93xtmoney has been a member for 9 full years93xtmoney has been a member for 9 full years93xtmoney has been a member for 9 full years93xtmoney has been a member for 9 full years93xtmoney has been a member for 9 full years93xtmoney has been a member for 9 full years93xtmoney has been a member for 9 full years
Topics: 25
Extra Info: Xt AWD
Postby Garpathen » July 30th 2011, 8:19am
Timing is top dead center Clamp wire on timing gun around number 1 cylinder plug wire
The other wire goes on a connector located left passanger side in the dog house if I remember it's a wire off the rottor. I no that is a
Black wire So with that top dead center on the crank,
Garpathen
Years of Membership: Garpathen has been a member for 9 full yearsGarpathen has been a member for 9 full yearsGarpathen has been a member for 9 full yearsGarpathen has been a member for 9 full yearsGarpathen has been a member for 9 full yearsGarpathen has been a member for 9 full yearsGarpathen has been a member for 9 full yearsGarpathen has been a member for 9 full yearsGarpathen has been a member for 9 full years
Alias (AKA): Gph
Extra Info: 4.3 V-6 rwd
It is currently August 10th 2020, 12:17am
Technical Information Forum
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
Date: Apr 14 '20
Time: 5:32am
Attached by: augidog
augidogaugidog is online!
Date: Jan 24 '20
Time: 2:28am
