Fuel filter leaking, Astro / Safari van
Postby TheBusAndUs [OP] » December 22nd 2017, 7:00pm
I changed the fuel filter on my 1995 and noticed the fuel filter was leaking upon reinstall. Napa had no solutions but Orileys carried this pack of fuel resistance o rings. I replaced the rear as it was leaking with the change, after doing that the front one leaked as well. So if you see your o rings with any type of damage just replace them BOTH before you reinstall the fuel filter. With this pack I’m now leak free!
Dorman 80020
TheBusAndUs
Years of Membership: TheBusAndUs has been a member for 2 full yearsTheBusAndUs has been a member for 2 full years
Topics: 7
Extra Info: AWD conversion
Re: Fuel filter leaking, Astro / Safari van
Postby RECox286 » December 22nd 2017, 11:48pm
Yep, good advice to be sure. I've seen assortments of o-rings, such as your picture points out,
in more than one A/P store, mostly in the "HELP" section.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
It is currently September 28th 2020, 12:03pm
Technical Information Forum
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
Date: Apr 14 '20
Time: 5:32am
Attached by: augidog
augidog
Date: Jan 24 '20
Time: 2:28am
cron
