Hey everyone. As the title says, i'm having a few problems. First off, I've been having problems with my EGR valve for about a year now. Whenever my engine would heat up, the car would start stalling. I unplugged the clip from the valve so that I could continue driving my car, but have been getting around 8 to 10 miles per gallon which is why I decided to replace it with a brand new one. When I was taking my old EGR out, one of the 2 bolts that hold it in place snapped off only leaving a small amount of threads sticking out. There really isn't enough thread to get a vice grip onto the bolt to get a strong hold. I have a set of bits to back out the bolt, but they require a hole to be drilled into the middle of the bolt first and this bolt is eating up my metal bits with no effort! There are no markings on the head of the bolt so I can't say what grade it is. Does anyone have suggestions as to getting that bolt out? Right now I have the other side bolted in and then a c-clamp tightened down on the broken bolt side, but that is very temporary.
My second question has to do with check engine codes. When I start my car up, I have no "Service Engine Soon" light, but after driving for about 15 minutes, the light comes back on and my car begins to run fairly poor. This van is an OBDI so when I got home, I put a paperclip in pins "a" and "b" and collected the error codes. Here is what I got and the info I found on them:
3 pause 2 - Error 32 - EGR error
6 Pause 6 - Error 66 - 3-2 Control Solenoid Circuit Fault
6 Pause 7 - Error 67 - Torque Converter Clutch (TCC) Solenoid Circuit Fault
8 Pause 3 - Error 83 - Torque Converter Clutch (TCC) Solenoid Circuit Fault
Has anyone seen these before and know what causes each one? The EGR was brand new so I can exchange it if that's the problem. Thanks in advance if you can help!
