COde PO454 emission
COde PO454 emission
Postby Born To Run [OP] » September 14th 2018, 1:00am
I have this code PO 454 evaporative emission system pressure sensor intermittent on my 2005 astro 2wd this van has 222,000 miles on it, runs great does not skip a beat.
Any thoughts or suggestions where to start looking ? Known issues, common causes etc.
My scan tool does not elaborate all that well !!
Born To Run
Years of Membership: Born To Run has been a member for 2 full yearsBorn To Run has been a member for 2 full years
Extra Info: Cargo van
Re: COde PO454 emission
Postby TurnNburn » September 14th 2018, 1:36am
I think Michael Jackson said it best, :whistle: just Bing it... just Bing it... :whistle:
https://www.obd-codes.com/p0454
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby dchan51360 » September 14th 2018, 6:01am
evap? My first inclination is check for vacuum leaks. at 222k. if you have not ever done it, replace all the vacuum lines. They are known to fail and 13 years/222k mi, you would be due. slow leaks in the vacuum system could easily cause intermittent errors with many different parts of the emissions system. Check for broken valves and elbows, (there are several plastic elbows connectors that will age and crack., then there are several solenoids and valves that can cause some strange problems too. Being that the engine runs pretty good, you are probably looking for a very small leak which is why I suggest you just to through the system and replace all the rubber vacuum lines.
dchan51360
Firing on 7 Cylinders (L1)
Postby AstroWill » September 15th 2018, 12:53am
TurnNburn wrote:I think Michael Jackson said it best, :whistle: just Bing it... just Bing it... :whistle:
Bing again? Ned Ryerson is that you?
Images: 473
Postby Born To Run [OP] » September 15th 2018, 6:44pm
Ok will check all vac lines etc.
I did erase code & have used van a few times & it has not returned yet.
Also the air bag light is on, module under seat got wet & rusted, installed a good used one but learned it has to be programmed to vehicle. What is the best method to fix/replace module & get programmed ??
Born To Run
Postby dchan51360 » September 15th 2018, 9:24pm
Any evap/emission errors can sometimes be caused by a leaky gas cap as well. Sometimes not getting a tight seal can trigger other evap errors other than a gas cap error. Just some where else to check. As far as the air bag light, that is any shop that has a tech ii or clone to program the airbag..
dchan51360
Postby AstroWill » September 15th 2018, 9:50pm
My guess would be a bad sensor or bad connection/wiring. Because it's not stating that there is a leak detected, it's saying that the signal from the sensor is intermittent.
Images: 473
It is currently April 12th 2021, 7:58am
Technical Information Forum
nsfkid1
Date: Apr 03 '21
Time: 9:22pm
LumaWJ
Comments: 21
Date: Mar 18 '21
Time: 8:54am
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
