MAF Question
MAF Question
Postby Van-GO [OP] » April 14th 2012, 10:56pm
I have a 2005 Astro AWD. WHat are the three wires for in the MAF sensor? Are two of them related to DC volts? if so, which is which? ( + or -) Thank You
Van-GO
Years of Membership: Van-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full yearsVan-GO has been a member for 12 full years
Alias (AKA): VanGeorge, DR Gyro and Van-GO
  • FSM Question
    by AstroOafAdventurer » August 8th 2020, 12:20pm in Technical Information
    Last post by augidog View the latest post
    August 12th 2020, 10:32pm
    51
    December 1st 2020, 12:07am
Re: MAF Question
Postby chevymaherchevymaher is online! » April 15th 2012, 2:50am
One is hot, one negative. The third is a signal to the ecm. To find hot and negative test with a volt/ohm meter on the plug on the vans wiring harness. One will test hot 12V with the key on. One will show continuity to a ground. The signal wire will show a milivoltage which varies and is random.
It is currently December 1st 2020, 12:07am
Technical Information Forum
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
Date: Apr 14 '20
Time: 5:32am
Attached by: augidog
augidog
Date: Jan 24 '20
Time: 2:28am
