won't start
won't start
Postby rlbautoworks [OP] » April 3rd 2009, 1:48am
I have a '98 safari awd with a 4.3.New fuel pump installed 2-weeks ago.Ran fine took kid to school came home got ready to leave for work won't start[turns over great].Shows codes P0102,P0304,P0452.Think I have a leaking intake[losing anti-freeze nothing in oil].Have not done compression check to see if it's head gasket[s].Anybody been through this? :feedback:
rlbautoworks
Years of Membership: rlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full yearsrlbautoworks has been a member for 12 full years
Re: won't start
Postby Matrixx » April 3rd 2009, 7:56am
Hi rlbautoworks
-When was the last tune-up done on the vehicle?
-Did all 3 of those codes come up at the same time?
-I'm sure you replaced the fuel filter with the fuel pump, correct?
If it doesn't start when it's stone cold, then check for spark with both the coil wire and a spark plug wire.
Please keep us updated, Thanks.:)
Matrixx
Re: won't start
Postby rlbautoworks [OP] » April 3rd 2009, 8:54am
Fuel filter was replaced with the pump.All three codes were found at the same time[never checked them till it went DOA].Replaced rotor,and cap.Have not gotten to the plugs and wires[purchased,not installed].Has good spark at cap.Been working alot of ot,hope to get back at it this weekend.
rlbautoworks
Re: won't start
Postby spongebob218 » April 3rd 2009, 12:32pm
The codes are indications of problems, but even with a MAF problem, a miss on cyl. #4, and an FTP sensor issue it should still start. Start with fuel pressure and spark.
You ain't nothin' unless you have green plugs.
spongebob218
Years of Membership: spongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full years
Re: won't start
Postby rlbautoworks [OP] » April 4th 2009, 2:41am
Thanks for the advice.Found leaking fuel under van.Traced it to a fuel line became unhooked[can't beleave it ran for two weeks].Rehooked line,it started right up,and low and behold all codes were cleared.Never have had a repair go this quickly[it pays to start with the basics and go from there].Still worried about the anti-freeze level.Guess I'll have to look further into this.Thanks again for your help as well as just listening.
rlbautoworks
Re: won't start
Postby Matrixx » April 4th 2009, 10:56am
Hi rlbautoworks
Wow, you maybe right about the fastest repair, hehe. I'm glad to hear things are running fine now.
Yes, I would check that coolant leak for sure.:)
Matrixx
It is currently December 4th 2020, 6:42am
Technical Information Forum
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
Date: Apr 14 '20
Time: 5:32am
Attached by: augidog
augidog
Date: Jan 24 '20
Time: 2:28am
