Hard start, sputtering
Postby ATS666 [OP] » January 27th 2014, 4:54pm
Hi, All
I have a 2002 GMC saffari cargo van 2wd, engine code X
148,000 kms
Tune up was done a year ago (15,000 kms) Plugs, wires, cap, rotor, pcv, fuel filter, air filter, ignition coil.
It starts and stalls 5-6 times before it stays running.
If you stab the throttle it will sputter and pop a few times and then accelerate fully.
Has a code for random cyl misfire
Last week:
Cleaned the throttle body and IAC
Installed a new fuel filter.
Installed a new distributer because one of the mounting tabs was cracked for the cap, also the distributor gear had abit funny wear to it considering it's not a high mileage vehicle.
Cleaned the maf sensor.
Just bought a fuel pressure gauge and hooked it up today (Jan 27 2014)
Fuel pressure koeo is 60 and then drops to 54 and will hold there a long time.
Idling 52 psi
2000 rpm 50 psi
If you stab the throttle psi will spike to 60 and then come down to 50.
Am I safe to assume I need to replace the fuel pump?
Thanks
ATS666
Years of Membership: ATS666 has been a member for 7 full yearsATS666 has been a member for 7 full yearsATS666 has been a member for 7 full yearsATS666 has been a member for 7 full yearsATS666 has been a member for 7 full yearsATS666 has been a member for 7 full yearsATS666 has been a member for 7 full years
Van Model Year: 2002
Extra Info: Cargo van 2wd
Re: Hard start, sputtering
Postby chevymaher » January 27th 2014, 5:14pm
Fuel pressure is fine so the pump is good.
Read codes and check for dirty connections to sensors.
Topics: 91
It is currently April 13th 2021, 6:14pm
Technical Information Forum
nsfkid1
Date: Apr 03 '21
Time: 9:22pm
Attached by: LumaWJ
LumaWJLumaWJ is online!
Comments: 21
Date: Mar 18 '21
Time: 8:54am
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
