Passlock headache
Passlock headache
Postby leadfoot [OP] » February 21st 2014, 7:08pm
Hi folks. I must first admit that I joined so I could solicit a little help getting my little brother's 99 Safari up and running. It is the basic passlock/security issue. I have
already replaced the ignition housing with a new GM, then the key and tumbler with an aftermarket one. I cannot seem to get the system to re-learn the new key despite using virtually every reset combination I can find. I need to know what my next step is. Seems most people that replace the parts do not have any issues getting the system reset.
Just a little history, it quit on him and he took a lot of stuff offit, including the front of the engine. He has the belt off the alternator. I cannot see a reason it won't start without it. I have a good charger on the battery, and it does the initial start and shuts off in about 2-3 seconds.
I am at my wit's end, and need to get this thing off my lift. Any suggestions will be highly appreciated.
Thanks!
Jim
leadfoot
Years of Membership: leadfoot has been a member for 6 full yearsleadfoot has been a member for 6 full yearsleadfoot has been a member for 6 full yearsleadfoot has been a member for 6 full yearsleadfoot has been a member for 6 full yearsleadfoot has been a member for 6 full years
Extra Info: V6 2WD
Re: Passlock headache
Postby sfeaver » February 22nd 2014, 2:07am
What does the security light do? Flashing after trying to start?
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 21
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Postby leadfoot [OP] » February 22nd 2014, 8:52pm
It stays on, steady. Never flashes. I'm taking the aftermarket key and set out and retrying the old oem. Removed the oem because the key was so worn it kept hanging up. No spare key available
leadfoot
Extra Info: V6 2WD
Postby safariking » February 22nd 2014, 9:27pm
the security dosn't usually set unless it is flashing however the way to do it is disconnect the battery for about 5 minutes. reconnect battery turn key to run position,security light will flash for about 10 min then go solid when it does give the key a quick jolt but don't try to start it. do the same process 3 times on the 3rd time when the lights solid turn the key and start it. if you've done it correct it will start when its running with the upper and lower plastic covers removed from the steering column unplug the 3 wire plug where the ignition is (believe its black, red,yellow and then the light will stay solid but the security system will be disabled. IMPORTANT:when you unplug the wire the truck must be running! good luck
safariking
Years of Membership: safariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full years
Topics: 23
Images: 9
Extra Info: SLE 4.3
Postby leadfoot [OP] » February 23rd 2014, 1:21am
I'll give it a try in the morning. I have had the battery disconnected several times, but I do not recall the security light flashing afterwords, only solid. I'll leave the battery off for a good while, as I may not have had it disconnected long enough before. Thanks for the assist, will report findings tomorrow.
Jim
leadfoot
Extra Info: V6 2WD
Postby leadfoot [OP] » February 23rd 2014, 5:38pm
Security light never flashed, stayed solid. Would there possibly be a code that needs to be reset?
leadfoot
Extra Info: V6 2WD
Postby safariking » February 23rd 2014, 5:52pm
try doing the procedure i mentioned above see if it works what makes you think it might be a passlock problem
safariking
Topics: 23
Images: 9
Extra Info: SLE 4.3
Postby leadfoot [OP] » February 24th 2014, 2:30am
I did the procedure. Light stayed steady when the battery was hooked back up. I did the procedure anyway and the security light stayed steady the whole time. Reason I felt it was the passlock is the engine starts then dies within a couple seconds after starting. Fuel pressure is good and never drops off. Coil has fire. Only thing I could think of was the fuel injection shuts the engine down, symptom of passlock failure. I would certainly welcome any other options I can explore.
Thx,
Jim
leadfoot
Extra Info: V6 2WD
Postby redfury » February 24th 2014, 4:12am
Same problem with another member here. Can you read your computer with a scanner?
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby leadfoot [OP] » February 24th 2014, 5:22pm
No scanner. Gonna try and borrow one or persuade a GM Tech buddy of mine to assist. I think its coming down to that...
leadfoot
Extra Info: V6 2WD
Postby leadfoot [OP] » February 26th 2014, 12:53pm
GM Tech and I spent 3 hrs chasing wires and using diagnostic equipment. Passlock is not talking to computer, possibly the theft deterrent module. I've decided not to buy anything else to try and trouble shoot it. I'm buying a credit for his laptop tuner and he will program the passlock out of the computer. If that works, and he assures me it will, it will be a good $100 spent. I won't disappear if it fixes it, rather ill post results so it might help someone else.
Thanks for all the input,
Jim
leadfoot
Extra Info: V6 2WD
Passlock headache also
Postby subwoof » February 26th 2014, 11:48pm
Hello!
Have the exact same issue with a donor 2000 astro that the security light is always on. Previous owner(s) did the resistor bypass but cannot reprogram with it or when returned to stock. Ignition switch / hall sensors and fixed resistance all work when checked so it's a definite brainfart.
I pulled the BCM and resoldered the PWB connections, de-ox'ed the pins and no change. Pulled the instrument cluster and did same. No change.
Since this is astro #3 and all have this system, it's a foregone conclusion to buy a decent scanner with the option to nuke the security all together...
sub
subwoof
Years of Membership: subwoof has been a member for 6 full yearssubwoof has been a member for 6 full yearssubwoof has been a member for 6 full yearssubwoof has been a member for 6 full yearssubwoof has been a member for 6 full yearssubwoof has been a member for 6 full years
Alias (AKA): Subwoof
Postby leadfoot [OP] » March 1st 2014, 4:34pm
Well van is running. Had a friend use HP Tuner to delete the security system, then reflash the Computer. Engine runs now, with a security light on but that's not an issue, it's just an old work van anyway. Security is bypassed and little brother gets his van back. I did have to buy two credits for the HP Tuner, but that was worth every penny of the hundred bucks!
Main reason for the delete was because the computer wasn't seeing the passlock, and it could have been the TDM or a broken wire somewhere. We just decided to spend the money that we knew would get it running versus buying more parts and hoping they fixed it.
Thanks for the input
Jim
leadfoot
Extra Info: V6 2WD
Postby steyr223 rob » January 28th 2017, 8:15pm
I know this is an old thread but what is a hp tuner and how did u flash the computer after clearing it where did u get the software, not a mechanic understand computers but not familiar with car computers
Same issue and my work truck has been stuck at mcdonalds for a week now . No work no money
Thanks
steyr223 rob
Years of Membership: steyr223 rob has been a member for 3 full yearssteyr223 rob has been a member for 3 full yearssteyr223 rob has been a member for 3 full years
Extra Info: 4.3 v6
It is currently December 3rd 2020, 11:29am
Technical Information Forum
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
Date: Apr 14 '20
Time: 5:32am
Attached by: augidog
augidog
Date: Jan 24 '20
Time: 2:28am
