Airbag light on
Airbag light on
Postby 99Astro99 [OP] » May 8th 2014, 4:35am
Evening,
just put some new exhaust donuts in and when I started the van up... Airbag light is staying on???
Recent;y installed a complete tilt column (steering wheel and airbag intact) is the only thing that I have wrokeed on relating to airbag system....
Any ideas??? have to stop and borrow a scanner as mine won't do airbag code scans
thanks
99Astro99
Years of Membership: 99Astro99 has been a member for 8 full years99Astro99 has been a member for 8 full years99Astro99 has been a member for 8 full years99Astro99 has been a member for 8 full years99Astro99 has been a member for 8 full years99Astro99 has been a member for 8 full years99Astro99 has been a member for 8 full years99Astro99 has been a member for 8 full years
Extra Info: 4.3L RWD
Re: Airbag light on
Postby chevymaher » May 9th 2014, 2:37am
Not sure what exhaust and airbags have in common.
Maybe you knocked a sensor wire off or loose while you were under there. Mine are in the lower core support. Scanner is the place to start.
Re: Airbag light on
Postby astroman97 » May 9th 2014, 3:31am
Only spit balling a idea...could it be the clockspring? Ribbon broke? Connector under the dash loose disconnected?
astroman97
Years of Membership: astroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full years
Topics: 78
Images: 2
Extra Info: Also 97 both 2wd
Re: Airbag light on
Postby 99Astro99 [OP] » May 9th 2014, 3:47am
thinking....
I removed the floor mat (soaking wet from leaking windshield) and hosed the front floor out to clean it up.... going to pickup a used airbag module and see if that takes care of it.... haven't found anyone local who can pull airbag codes,,,, maybe look into buying additional modules for my scanner... just seemed odd that the light came on a week and a half after I hosed the floor out
99Astro99
Re: Airbag light on
Postby CoolCat4Christ » May 10th 2014, 6:48am
chevymaher wrote:Not sure what exhaust and airbags have in common......
If you guys would have been given the opportunity to meet witchiepoo, my brothers ex-wife, you'd know what exhaust and airbags have in common..Image
17553ImageImage
"If guns cause crime, all of mine are defective." -Ted Nugent
CoolCat4Christ
Years of Membership: CoolCat4Christ has been a member for 6 full yearsCoolCat4Christ has been a member for 6 full yearsCoolCat4Christ has been a member for 6 full yearsCoolCat4Christ has been a member for 6 full yearsCoolCat4Christ has been a member for 6 full yearsCoolCat4Christ has been a member for 6 full years
Images: 7
Location: Born In East L.A. Currently residing somewhere in the San Gabriel Valley of Southern California
Van Model Year: 2002
Extra Info: LS 4.3l RWD
It is currently October 1st 2020, 6:03am
Technical Information Forum
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
Date: Apr 14 '20
Time: 5:32am
Attached by: augidog
augidog
Date: Jan 24 '20
Time: 2:28am
