OBD II P0441
OBD II P0441
Postby gejettest [OP] » June 11th 2010, 6:47am
Hello,
1996 Safari van here, 227,000 miles, original owner, just changed my second set of intake manifold gaskets, and this code is now on. I did some research on it, any one else have this one come up? Is there a most likely suspect or place to start? I changed the gas cap, just to see if it was that obvious with a friends, no difference. Any parts or systems to test to find the culpret?
Thanks,
Henry
gejettest
Years of Membership: gejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full yearsgejettest has been a member for 11 full years
Alias (AKA): gejettest
Van Model Year: 1996
Extra Info: 2wd 259k mi
Re: OBD II P0441
Postby Astroplane » June 11th 2010, 8:33am
What scanner are you using to get this code? P0441 is a GM EVAP code, but I'm not sure it applies to your van. How about P1441, 'EVAP System Flow during non-purge'?
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Re: OBD II P0441
Postby gejettest [OP] » June 12th 2010, 5:20pm
Hi,
I'm using an Actron CP9175 OBD II AutoScanner, here is a picture of the fault screen.
I plan on pulling the doghouse off today and look for obvious things like connections, hoses, etc.
Thanks,
gejettest
Re: OBD II P0441
Postby Astroplane » June 13th 2010, 7:03am
At first, I thought it might be a difference between your '96 and my '97. I'm leaning toward a difference in our scanners. The '97 FSM does not show this code. I would inspect the purge valve vacuum supply port (is there vacuum with engine at idle?), the purge valve itself, and the line from the canister to the valve. Please let us know what you find.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Re: OBD II P0441
Postby gejettest [OP] » November 24th 2010, 2:48am
Sorry for the very late reply, but I did find the problem. It was a disconnected vacuum line at the purge valve. Reconnected it, no problem since.
Thank you all for your help.
gejettest
It is currently January 19th 2021, 8:04pm
Technical Information Forum
Date: Jul 11 '20
Time: 11:15pm
Date: Jun 25 '20
Time: 11:03am
Date: May 29 '20
Time: 8:02am
Date: Apr 14 '20
Time: 5:32am
Attached by: augidog
augidog
Date: Jan 24 '20
Time: 2:28am
