junk yard hitch interchangeable models
Postby astronator [OP] » January 3rd 2017, 11:10pm
Only 3 astro/safaris at my local junk yard/ u=pull it. lots of trailblazers and other chevy products. will any other chevys match up?
I have an 03 safari awd. $22 if they have one that will work.
astronator
Years of Membership: astronator has been a member for 4 full yearsastronator has been a member for 4 full yearsastronator has been a member for 4 full yearsastronator has been a member for 4 full years
Extra Info: awd
  • Class III Hitch help 2" receiver opening
    by Safarimeister » September 10th 2020, 3:02pm in Towing/Trailers
    Last post by dcsleeperdcsleeper is online! View the latest post
    September 14th 2020, 4:58pm
    44
    March 3rd 2021, 4:13pm
Re: junk yard hitch interchangeable models
Postby WimpTech » January 3rd 2017, 11:21pm
No Clue, but pretty sure all A/S fit each other across the years.
For reference, here's the one that fits your van:
http://www.curtmfg.com/part/13035#tab=vehicles
I'd measure the holes on your current van and verify dimension before buying. The van is already setup with mounting locations and wiring.
http://www.etrailer.com is good about these things if you chat with them, they can probably tell you any other options.
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby Abe Froman » January 13th 2017, 11:21pm
I just thought I should put this here, I had a hitch off my 1986 Astro and have just installed it on my 2001 Astro. The 86 and the 2001 are Cargo vans, if it makes a difference which I think don't think it does.
Abe Froman
Years of Membership: Abe Froman has been a member for 6 full yearsAbe Froman has been a member for 6 full yearsAbe Froman has been a member for 6 full yearsAbe Froman has been a member for 6 full yearsAbe Froman has been a member for 6 full yearsAbe Froman has been a member for 6 full years
Topics: 12
Van Model Year: 2001
Extra Info: Cargo RWD
Return to Towing/Trailers
It is currently March 3rd 2021, 4:13pm
Towing/Trailers Forum
in Towing/Trailers
Comments: 22
Date: Mar 01 '21
Time: 10:49pm
in Towing/Trailers
Comments: 22
Date: Feb 28 '21
Time: 8:45pm
in Towing/Trailers
Comments: 53
Date: Dec 04 '20
Time: 11:04pm
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
Date: Oct 19 '20
Time: 7:10pm
