pulling van on a dolly trailer
Postby iceberg3303 [OP] » March 14th 2018, 11:04pm
When towing a astro van on a dolly should you pull the drive shaft? Tow is about 150 miles 100 is freeway pull?
iceberg3303
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: iceberg3303 has been a member for 3 full yearsiceberg3303 has been a member for 3 full yearsiceberg3303 has been a member for 3 full years
Topics: 40
Images: 16
Alias (AKA): bill
  • 94 AWD - can I tow it on a dolly?
    by underhill » January 10th 2021, 11:17pm in Towing/Trailers
    January 12th 2021, 12:57am
    19
    March 1st 2021, 7:56am
Re: pulling van on a dolly trailer
Postby chevymaher » March 14th 2018, 11:17pm
Yes if you like your transmission.
Postby AstroWill » March 14th 2018, 11:54pm
chevymaher wrote:Yes if you like your transmission.
+1
iceberg3303 wrote:When towing a astro van on a dolly should you pull the drive shaft? Tow is about 150 miles 100 is freeway pull?
Yes, it must be disconnected, unless it's very short slow speed trip(20 under 40mph or something like that sticks in my head). Or if you can leave the engine running in neutral for the duration of the tow, that would work as well.
Images: 472
Postby Rinny » March 15th 2018, 12:14am
Just get a u haul car carrier.
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full years
Images: 6
Extra Info: 5.7L NP236
Postby Mmusicman » March 15th 2018, 12:18am
Or tow it backwards?? .... (rear wheels off the ground) :D
(does not apply to AWD)
Topics: 73
Images: 49
Postby iceberg3303 [OP] » March 15th 2018, 12:38am
+1
If you pull drive shaft do you need to plug tail shaft from leaking trans fluid??
iceberg3303
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 40
Images: 16
Alias (AKA): bill
Postby AstroWill » March 15th 2018, 12:44am
Mmusicman wrote:Or tow it backwards .... (rear wheels off the ground) :D
Not recommended by any MFG that I have ever seen, actually most will expressly say not to. Once that sucker starts swaying and you loose all control, might regret that decision.
iceberg3303 wrote:
+1
I would leave it attached at the transmission and tie it to the body of the van. If it was something to be done on a regular basis, I would get a manual driveshaft disconnect installed($$$).
https://sites.google.com/site/astrosafariinfo/towing
Images: 472
Postby iceberg3303 [OP] » March 15th 2018, 12:55am
I read the link so you have to use the spare dounots to load it what about fender clearance?
iceberg3303
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 40
Images: 16
Alias (AKA): bill
Postby AstroWill » March 15th 2018, 1:07am
It's the platform that the tires sit on that is narrow, plenty of fender clearance, unless they have changed their setup.
Of course on a proper full sized tow dolly, it wouldn't be an issue, just the u-haul ones.
Images: 472
Postby Mmusicman » March 15th 2018, 1:43am
https://www.answers.com/Q/Is_it_legal_t ... _backwards
http://backroadtravelers.com/waystotow.html (3rd paragraph)
Maybe not recommend or ideal... but I saw it done in the old days.
I'm not recommending it either, but apparently it can be done.
Drive shafts are easy enough to pull, to do it right.
Topics: 73
Images: 49
Postby AstroWill » March 15th 2018, 1:51am
Still not something I would recommend, nor the MFGs would recommend. Might be a little different behind a 10,000# tow truck that has a lift attached to it... to each their own.
Images: 472
Postby Mmusicman » March 15th 2018, 1:54am
You answered before I could edit my post saying I don't particularly recommend it either. :)
Of course I'm sure the manufacturer would be very against lifting and modifying a vehicle too!
Topics: 73
Images: 49
Postby AstroWill » March 15th 2018, 1:56am
I had already hit quote and was in the middle of my reply when the phone rang, it happens ;)
So I only quoted the original post.
Images: 472
Postby Leeann_93 » March 15th 2018, 2:08am
It fits on a Uhaul car trailer. The donuts are if you use the Uhaul dolly.
Postby iceberg3303 [OP] » March 15th 2018, 3:09am
Thanks everybody for your great imput!!!! this great group of astro van guys & gals if they are reading this also!!! thanks againg!
iceberg3303
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 40
Images: 16
Alias (AKA): bill
Postby Birdshake » March 15th 2018, 5:27am
My old awd '03 wouldn't start one time in the woods 80km from a paved road, the tow truck driver wouldn't use his dolly on the dirt roads so he tried to disconnect the driveshaft. The thing was fused with rust like everything else on that van. He ended up using the dollies.
2005 4WD Astro Cargo
NP236 3.73 Eaton Posi
S10 HD Springs 3" blocks
245/75/16 BFG KO2
KYB Monomax
Birdshake
Years of Membership: Birdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full years
Topics: 10
Images: 28
Extra Info: 4.3 AWD
Postby Toskavat » March 15th 2018, 12:56pm
The first post in the Uncategorized - what have you done to/with your van today, show nice pics of using a tow dolly for pulling an Astro/Safari.
Toskavat
Years of Membership: Toskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full years
Images: 24
Alias (AKA): ASTRORC
Extra Info: 4.3 V6 2WD
Postby markmitch » March 15th 2018, 4:51pm
I used to have the input part of a Chevy drive shaft just for that when I used to buy scrapper vehicles to pull parts then haul to the scrap yard back when junk prices were way up but I think I tossed it when we moved to California. Its a cheap way to keep trans fluid from dumping on the ground which in some places is a high fine. remove front wheels/tires bolt on a set of the donut spares on it. Drive or push the van onto the dolly. drop the rear section of the drive shaft but still put the trans in neutral so the shaft is not rolling around. Tie the drive shaft up to the body or put a cargo strap across from side to side to hold the driveshaft up then go. Now after a few turns and such pull over and check everything. You should be fine. You may wish to check periodically all the straps and such. I don't believe I have ever towed that distance but I have done many tows 50 miles or less when I was scrapping back in New Hampshire. Made a lot of extra cash doing that.
Firing on 8 Cylinders (L6)
Topics: 626
Images: 20
Extra Info: RS V8 AWD
Return to Towing/Trailers
It is currently March 1st 2021, 7:56am
Towing/Trailers Forum
in Towing/Trailers
Time: 8:45pm
in Towing/Trailers
Comments: 53
Date: Dec 04 '20
Time: 11:04pm
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
Date: Oct 19 '20
Time: 7:10pm
in Towing/Trailers
Comments: 21
Date: Sep 12 '20
Time: 7:47pm
