Astro On The Farm
Astro On The Farm
Postby Astroecho [OP] » August 29th 2020, 4:25am
The Astro works like a dream to pull the big hay bales! These are 1300lb bales and it takes them off trailer and skids them around like a dream.
Astroecho
Years of Membership: Astroecho has been a member for 6 full yearsAstroecho has been a member for 6 full yearsAstroecho has been a member for 6 full yearsAstroecho has been a member for 6 full yearsAstroecho has been a member for 6 full yearsAstroecho has been a member for 6 full years
Topics: 21
Re: Astro On The Farm
Postby sixsix » August 29th 2020, 12:52pm
Hey, good to see you out there...
Did not think I would see anyone else doing that besides US in Ky using a RWD, too
More Pics - keep us posted - what hitch are you using. Are your rolls dry. so many Qs
:banana: :banana: :banana: :banana:
I am so tired of 'Periods' - formally ending sentences is so overated / overrated / 'Z'
So only CAL, ILL & NY Elects
Firing on 6 Cylinders (L5)
Topics: 38
Images: 1320
Postby Astroecho [OP] » August 29th 2020, 6:26pm
Yes, a rwd astro. Just the original hitch which was on the van, no label or id. I'm using a Reese 7000lb ball mount with 4 3/4 ton screw shackle through the ball hole attached to 4 inch 20,000lb tow strap/s. Just the towing stuff I had around and all well over rated for the bales.
Astroecho
Topics: 21
Postby Astroecho [OP] » August 29th 2020, 6:27pm
And sorry, yes the bales are completely dry. They are big bales and average 1300lb dry weight.
Astroecho
Topics: 21
Return to Towing/Trailers
It is currently March 1st 2021, 11:28pm
Towing/Trailers Forum
MmusicmanMmusicman is online!
in Towing/Trailers
Comments: 17
Date: 38 minutes ago
Time: 10:49pm
in Towing/Trailers
Comments: 17
Time: 8:45pm
in Towing/Trailers
Comments: 53
Date: Dec 04 '20
Time: 11:04pm
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
Date: Oct 19 '20
Time: 7:10pm
