by tstol [OP] » February 28th 2021, 3:05am
by markmitch » February 28th 2021, 5:00am
by sixsix
» February 28th 2021, 5:12am
tstol wrote: There is already a hitch on the van. I don't know if it's a factory hitch, but it doesn't look like there's a towing package. ...
by zzimmer3 » February 28th 2021, 1:56pm
by tstol [OP] » February 28th 2021, 5:02pm
markmitch wrote:transmission cooler would be my first update. If your have not done it yet drop the transmission oil pan and change the filter then replace gasket and reinstall the pan and top it off.
by tstol [OP] » February 28th 2021, 5:42pm
by tstol [OP] » February 28th 2021, 5:43pm
by tstol [OP] » February 28th 2021, 5:48pm
zzimmer3 wrote:You trailer setup will be easy peasy towing for your van. I've pulled alot more weight for years with no issues. I installed a tranny cooler, rear sway bar, and a brake controller (I don't think you'll need that at 1000#s). For trailer lights there is a bundle of wires neatly tucked in your jack storage area . Your van will pull 1000#s with ease.
by markmitch » February 28th 2021, 6:02pm
by tungtide » February 28th 2021, 7:32pm
by Mmusicman » February 28th 2021, 8:49pm
by Bossman » February 28th 2021, 11:56pm
by Mmusicman » March 1st 2021, 1:49am
Bossman wrote:Unless it has been done recently, it would be a good idea to service the rear axle ie: drain & refill
the differential. Fresh lube = happy diff when towing.
by DriveDog » March 1st 2021, 3:16pm
by tstol [OP] » March 1st 2021, 6:37pm
Mike
by sixsix
» March 1st 2021, 9:25pm
tstol wrote: ... So do you remove the plate?
by Bossman » March 1st 2021, 10:06pm
by Mmusicman » March 1st 2021, 10:50pm
by tstol [OP] » March 2nd 2021, 4:18am
by Bossman » March 2nd 2021, 5:22am
It is currently April 14th 2021, 12:07am
Towing/Trailers Forum |
Previous topic Next topic |
Sponsors |
